Author Topic: NerD TKL, getting caps/scroll lock to function  (Read 2484 times)
Offline KaminKevCrew
« on: Wed, 02 March 2016, 12:38:35 »
Hi there!
I built a GON TKL a few weeks ago, and I haven't been able to get the in switch caps/scroll lock leds to turn on and off. Does anyone know how to do that on this board?
Re: NerD TKL, getting caps/scroll lock to function
« Reply #1 on: Wed, 02 March 2016, 17:54:23 »
I'm assuming you've checked the LEDs themselves work and aren't in backwards, so next guess - are the resistors for them soldered on the board?
if they are more info would be good - are you running the default firmware or a customised layout?  Does backlighting work on those keys and/or others, if you're planning on having it?
« Reply #2 on: Wed, 02 March 2016, 18:48:08 »
Yeah, the leds work fine! Basically right now, they are always on. I've used the NerDy GUI to modify the key layout, and dim the leds a touch, but other than that I haven't changes anything. I haven't even changes the placement of where scroll lock and caps lock should be...
Offline axtran
« Reply #3 on: Thu, 03 March 2016, 21:51:17 »
The config in NerDy GUI shows different pins are used as indicators. Look at the PCB and you will see separate pins near Caps for the indicators.
MX Silent > MX Vintage Black > Everything Else
« Reply #4 on: Thu, 03 March 2016, 23:49:55 »
Ah. Thanks! I was hoping the in switch led could double as the indicator leds, since my plate has no holes for extra leds...
Offline axtran
« Reply #5 on: Fri, 04 March 2016, 12:01:05 »
Yeah--it's kind of annoying. I usually take a 2x3x4mm LED and some heat shrink and do a side-soldered LED. It works well with the acrylic out the side (esp since I use RGB two-post LEDs for Caps).
