Author Topic: [IC] Microdox IC (58-Key Ergodox)  (Read 6321 times)
Offline JorisBoers
  • ORANGE IS LOVE, ORANGE IS LIVE
« on: Wed, 02 March 2016, 16:16:48 »
Hello Geekhack,
[IC form] http://goo.gl/forms/CCZICbR13G
[Album] http://imgur.com/a/5A3Mu
PietPtr and I are thinking of running a GB for a 58-key version of the Ergodox.
So basicly it is the ErgoDox without the 1u thumb cluster key and the bottom row. He has an album ready with how it should look since he has build one for himself already.
This group buy will be for a kit containing the following:
- An acrylic case and plate
- Nuts and bolts to secure the case
- 2 Arduino Pro Micros, optionally with firmware already flashed on them.
- Male and female headers for the Pro Micros
- A cable to connect the two halves
- Rubber feet
- 100 Diodes
What you'd need to buy yourself if you decide you want to build it on your own:
- 58 Cherry MX compatible switches
- Wires
- Solder
We will also be able to build the board for you, but that will be more expensive.
Let us know what you think of this in the Google form at the top of the post, all feedback is appreciated.
Cheers
Link to Reddit: https://www.reddit.com/r/mechmarket/comments/48okq9/ic_microdox_ic_58key_ergodox/
Link to DeskThority: https://deskthority.net/group-buys-f50/topic-t13074.html
« Last Edit: Wed, 02 March 2016, 16:25:39 by JorisBoers »
"I know you'll come back to me, I'm like a good kind of herpes, I'm impossible to get rid of." - TenTenSeven
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: [IC] Microdox IC (58-Key Ergodox)
« Reply #1 on: Wed, 02 March 2016, 19:20:37 »
IC submitted. Good luck to you guys!
Offline balthaz4r
  • I have found my people
    • /u/balthaz4r
« Reply #2 on: Wed, 02 March 2016, 19:34:36 »
I'm interested! Submitted my IC form.
1. Why did you choose to put 1.25U(?) keys on the outer edge columns? Why not just make them 1U since no one will be hitting the outer edges of these keys anyway.
2. Will you have some option for tenting the halves, or at least have compatible holes in the case so I can insert my own DIY standoffs without me adding extra holes?
3. Can you give a link to the proposed default keymap?
Offline Parod
« Reply #3 on: Wed, 02 March 2016, 22:48:54 »
I'm interested.
What's the keymap like on the prototype?
My only complaint is that the 1.25 keys aren't compatible with complete ergodox sets, but w/e
Offline PietPtr
« Reply #4 on: Thu, 03 March 2016, 02:13:33 »
I'm interested.
1. I think I'll be changing them to 1.5u for keyset compatibility
2. I'd love to add this feature! I'll have to look into how exactly the Ergodox does this though.
3. http://www.keyboard-layout-editor.com/#/gists/fe5fff168190d53d1c3d This is what I am currently using, but it's still changing a lot. I realize that this keymap isn't ideal for most people, so all suggestions for a default keymap are welcome!
Offline simonyunhe
« Reply #5 on: Thu, 03 March 2016, 02:19:10 »
I'm interested.
I'm also think about 1u key for the side, so people can use kit from Plank/Adapter for key compatibility.
KeyBs:|RS96-Brown|GS-87-White|DIYer60-Red|VA68M-Brown|GS-ALT71-Blue|IKBC-108-Black|
KeyCs:|SA Carbon R1+2|SA Camping|SA Amazing Chocolatier|SA Commando 88 Ghost|SA Hyperfuse|SA Penumbra|SA Doom|SA Creamy Orange|SA Ocean Dolch|SA Lotus*72|SA Trouble Minds R2|DSA Granite|GMK TA|GMK Soware|XDA Mailstone|GM Ember|
Offline PietPtr
« Reply #6 on: Thu, 03 March 2016, 09:17:43 »
I'm interested.
Would a planck kit have enough 1.5u keys though?
