Author Topic: Hey y'all!  (Read 2527 times)
Offline ifearghal
Hey y'all!
« on: Thu, 03 March 2016, 23:37:53 »
Keyboard enthusiast from TX. Currently I have a Corsair K95 (reds) and I just ordered an 87 Key Code Keyboard (browns). I would love to swap out the switches on my K95 as a fun project.
CODE TKL: MX Browns/Raindrop DSA in Blue and White|
Corsair K95 Full Size: MX Red: OEM
Re: Hey y'all!
« Reply #1 on: Sat, 05 March 2016, 22:24:48 »
Welcome to Geekhack!
Nice couple of keyboards, especially the CODE (I have one with clears).
Swapping switches is relatively easy, if you have a decent soldering iron and lots and lots of patience.  After the first few switches it becomes very routine.
Any idea what switches you'd swap for?
Offline ifearghal
Re: Hey y'all!
« Reply #2 on: Mon, 07 March 2016, 08:15:06 »
Im still trying to decide on that. It is a wonderful gaming keyboard. But I do wan't something a little quieter and tactile. Clears are a great option but I am still trying to make up my mind.
Re: Hey y'all!
« Reply #3 on: Wed, 09 March 2016, 03:28:11 »
You won't be able to do much about making non-clicky switches quieter, unless you install O-rings under the keycaps so soften the downstroke.  Unfortunately it also reduces the travel distance, but perhaps that won't bother you as much.
Offline ifearghal
Re: Hey y'all!
« Reply #4 on: Wed, 09 March 2016, 07:53:03 »
I don't think it will, only because it will be used for gaming primarily. I'm back and forth about it, of course, and may decide to go to a loud blue or green depending on the feel of the switch.
I should probably get a switch plate to try out.
Re: Hey y'all!
« Reply #5 on: Sun, 13 March 2016, 19:23:11 »
A switch tester will only give you so much impression of what the switch is like.
You really can't beat typing on a keyboard with each switch.
