Author Topic: Can I Cut off Unnecessary Wires From An RGB-LED?  (Read 2000 times)
Offline Row009
« on: Thu, 03 March 2016, 23:39:39 »
Hello,
If i was to cut off the red and the blue wires of an RGB-LED (Attached to a keyboard), Would it glow only in green or will it not work at all?
Photo for example --
Offline appleonama
  • Trollo en USA
Re: Can I Cut off Unnecessary Wires From An RGB-LED?
« Reply #2 on: Thu, 03 March 2016, 23:45:44 »
You can do anything you want man
Offline jd29
« Reply #3 on: Thu, 03 March 2016, 23:46:55 »
If the leads are not connected to anything on your design, cutting them will affect nothing. People usually cut the extra length off pins after soldering... it's fine.
