Author Topic: Win7 64 bit keyboard problems  (Read 5874 times)
Offline JohnMD1022
    • http://springcreekrhapsody.blogspot.com
« on: Mon, 07 December 2009, 12:15:27 »
2 IBM Space Saver keyboards (Part No 1391472 1397681) do not map properly.
Daskeyboard Professional: When connected to the system, the PC will not boot.
Any thoughts on these 2 problems?
Offline ch_123
« Reply #1 on: Mon, 07 December 2009, 12:21:11 »
What exactly do you mean by "not mapping correctly"?
Offline GenEric35
« Reply #2 on: Mon, 07 December 2009, 15:09:38 »
so far i ran 2 model m, one AT->PS/2 and one PS/2, on windows 7, also a unicomp customizer usb, and a abs m1 usb, so far they work normally, both in the boot sequence and in windows 7 itself, i use windows 7 ultimate, the version released in october
Edit: After thinking for a bit, i remembered something, I did encounter a temporary problem with my IBM Model M 71G4544 after leaving plugged overnight, i came back and it wasn't working, rebooted, the keyboard registered until boot sequence started to load windows, then failed, I could not get it to work, i left it there for a week, it crossed my head that it could be a ground problem or something like that that accumulated over night, because the board was working find the night before, I don't use hibernate or sleep, but i do use auto shudown of monitor and start monitor on keyboard click
then a few weeks after, I opened the board to try a few things, first thing i did was unplug the ground from the keyboard backplate, rubbed the two wires on the backplate, then scew the ground back on, first minute there was no change, I typed a few keys while thinking of other things to change, then all of a sudden it started working, the only change I had done was the ground, but i can't be sure if thats what fixed it
« Last Edit: Tue, 08 December 2009, 20:01:03 by GenEric35 »
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline ricercar
  • mostly abides
« Reply #3 on: Mon, 07 December 2009, 15:18:04 »
Quote from: JohnMD1022;139787
I've had this happen with a PS/2 Kinesis Contour used with recent model Thinkpads (T60 and a forgotten model) within the last year. To what machine are you connecting the keyboard?
It appears to me to be a power draw issue. With a generic USB-PS/2 adapter, the Thinkpad woudl boot, but the keyboard failed to send modifier keys, such as shift, ctrl, alt, etc. Only the letter key was sent unless the timing was slowed very much.
Ctrl ... pause ... S - would save.
Shift ... pause ... A - would capitalize.
Search these forums for "blue cube" USB-PS/2 adapter for the solution that worked for me. I'm typing problem free on a Kinesis + blue cube + Thinkpad now.
« Last Edit: Mon, 07 December 2009, 15:20:33 by ricercar »
Offline ch_123
« Reply #4 on: Mon, 07 December 2009, 16:19:07 »
Quote from: ripster;139858
64 bit??
I doubt that that's making much of a difference, but for the record, I've been running 64bit Windows 7 on several machines since this time last year. No problems with any keyboard I've tested it with.
The Das problem sounds like generic "Should have bought a Filco" syndrome, the Space saver thing is a bit vague and needs a more detailed explanation.
Offline savage
« Reply #5 on: Mon, 07 December 2009, 17:58:40 »
Your mobo could be on the way out.
Offline ch_123
« Reply #6 on: Mon, 07 December 2009, 18:12:15 »
Wouldn't jump to that conclusion so quickly. The Das causes that problem for loads of people. Fortunately they will take them back and give a full refund.
Offline InSanCen
« Reply #7 on: Tue, 08 December 2009, 02:49:31 »
I suspect that power draw is indeed the issue (If it were just the DAS, it likely wouldn't be). Get a blue cube.
Having said that, I have ran 1391406's an M13 and a Wang 724 on Win7-64 without a single problem. All of them were on native PS/2. The motherboards, tended to be higher-end (P45, P35 and currently on an NF-570 chipsets).
I wonder if it's the chipset that defines the available current on PS/2 or the Manufacturers implementation of the board?
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #8 on: Tue, 08 December 2009, 17:08:06 »
I need some blue cubes for my keyboards.
Offline ch_123
« Reply #9 on: Tue, 08 December 2009, 17:35:41 »
Why not use the PS/2 ports?
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #10 on: Tue, 08 December 2009, 17:39:44 »
Quote from: microsoft windows;140244
Then it might be a good idea to buy some. (If you'd need multiple ones at once, I'd rather go for the trusty Belkin instead though - I don't think two Blue Cubes will fit two adjacent USB ports.)
Quote from: ch_123;140252
#keyboards > #computers, I guess, same here... (Plus it's nice to dig out a less-used board spontaneously and use it for a bit sometimes.)
Pity we only come with two hands, non-upgradable...
« Last Edit: Tue, 08 December 2009, 17:45:08 by keyb_gr »
« Reply #11 on: Tue, 08 December 2009, 19:05:30 »
The PS/2 ports in some of my machines do not always output enough power at startup. Like I said, it's good to use USB as a last resort.
Offline GenEric35
« Reply #12 on: Tue, 08 December 2009, 19:49:21 »
64 bit??
I did my tests on 64bit Win7 yes, there was no problem so far, even in virtual pc or vmware, I haven't had any problems so far, new win7 shortcuts work too
Edit: I did encounter a temporary problem with my IBM Model M 71G4544 after leaving plugged overnight, i came back and it wasn't working, rebooted, the keyboard registered until boot sequence started to load windows, then failed, I could not get it to work, i left it there for a week, it crossed my head that it could be a ground problem or something like that that accumulated over night, because the board was working find the night before, I don't use hibernate or sleep, but i do use auto shudown of monitor and start monitor on keyboard click
« Last Edit: Tue, 08 December 2009, 20:00:02 by GenEric35 »
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline GenEric35
« Reply #13 on: Tue, 08 December 2009, 20:02:51 »
I added this to my previous post above, but adding it too here, as it might be relevant
After thinking about, I did encounter some odd problem, I had used my keyboard at work on xp, worked fine, brough it home, used it on win7, then
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline ch_123
« Reply #14 on: Wed, 09 December 2009, 08:08:55 »
Quote from: ripster;140338
The 71s I believe have that funky pressfit connector to the controller board like the 42H - a common failure point.
I don't think so.... I assume this is the rubber dome Model M we're talking about?
Offline savage
« Reply #15 on: Wed, 09 December 2009, 09:21:18 »
OP has disappeared.
Yeah, his computer won't boot....lol
Offline JohnMD1022
« Reply #16 on: Thu, 10 December 2009, 06:31:04 »
Not mapping correctly = press a key and get a wrong character... e.g., press 'm' and get '0'
Both Space Savers are PS/2
Win 7 64 bit
Offline Mnemonix
« Reply #17 on: Thu, 10 December 2009, 06:38:25 »
Quote from: JohnMD1022;140865
Win 7 64 bit
That's the numpad feature of the keyboard. Hit Num Lock, then try again.
There might also be an option in your BIOS that turns on Num Lock during boot--disable that one.
Offline JohnMD1022
« Reply #18 on: Thu, 10 December 2009, 06:38:29 »
Space Savers + blue cube made no difference.
These on an Intel E8400 machine, MSI P35 MB.
The Das works on that box but not on a AMD Phenom II X3 720 machine with BioStar 790 GX MB
Offline ch_123
« Reply #19 on: Thu, 10 December 2009, 08:33:15 »
Did you try Shift+Scroll?
Offline JohnMD1022
« Reply #20 on: Thu, 10 December 2009, 08:43:26 »
Turning off Num Lock in the BIOS solved the Space Saver problem.
Thanks for the suggestion Mnemonix...  :)
Offline rdjack21
« Reply #21 on: Thu, 10 December 2009, 10:29:53 »
Quote from: ripster;140914
Just to be clear the IBM Space Saver can toggle the embedded numpad at any time with SHFT+SCRLK.  On mine I don't need to touch the BIOS.
No DIP switches are needed :biggrin1:
But I like my DIP switches
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
« Reply #22 on: Thu, 10 December 2009, 18:52:57 »
I like the ones on my printer.
Offline InSanCen
« Reply #23 on: Sat, 12 December 2009, 14:23:06 »
Quote from: microsoft windows;141132
They still make papyrus for it?
« Reply #24 on: Sat, 12 December 2009, 14:51:49 »
Yes they do. Then still make the BC-02 cartridge for it too. And it's a LOT cheaper than a black cartridge for a new printer.
Offline Santa
« Reply #25 on: Tue, 15 December 2009, 18:19:14 »
Honestly this happend to me too with my new computer that has win7 64-bit.
PS/2 mice and keyboard just would not work. I tried turning off the computer and plugging it in at that point and that did the trick for me :)
