Author Topic: Desoldering SIP-Sockets: Impossible for newbies???  (Read 7682 times)
Offline hKing
  • I am ze Ubermensch!
« on: Sat, 05 March 2016, 05:46:35 »
Hello there,
the last days I tried to desolder my Winkeyless Bface because I want to swap the top plate.
Desoldering the switches isn't a big problem (I work with a normal desolder pump and solder wick if needed) for me although I am a total noob.
Desoldering the SIP-sockets is a real pain in the ass, it just doesn't work.
The holes for the SIP-sockets / LEDs are so small, it seems that I am unable to get the solder out of the hole. Solder wick or repeated pumps with the desolder pump doesn't work ...
Help!!!!!!  :eek:
Offline axtran
Re: Desoldering SIP-Sockets: Impossible for newbies???
« Reply #1 on: Sat, 05 March 2016, 07:58:38 »
You have to add a lot of solder and flux. Remember that the heat has to conduct through the lead in order to get to all of the remaining solder in the hole--applying the iron doesn't conduct heat transfer as well as you would think. When pulling with the desoldering pump, ensure that you are also holding the iron so that it draws heat along the path toward the desoldering pump to ensure it does not prematurely cool. It's a pain, and you'll have better luck with a proper desoldering iron.
MX Silent > MX Vintage Black > Everything Else
« Reply #2 on: Sat, 05 March 2016, 08:16:25 »
Yeah, desoldering LEDs is not fun.  I find it easier to add solder to join both leads together in one molten blob then pull out the LED, and finally clean up the solder, but not sure how well that would work with SIP sockets as there really isn't much to pull on.
Offline hKing
« Reply #3 on: Sat, 05 March 2016, 09:52:29 »
This sound like an idea, but as you said: There isn't much to pull because they are located within the switch.
Offline merlin64
    • MechMerlin
« Reply #4 on: Sat, 05 March 2016, 16:18:17 »
This desoldering pump has cut down my desoldering time by half or more. This has worked with sip sockets very well. It takes a while to heat up though so, be patient. For $15 you can't go wrong.
http://www.amazon.com/Tenma-21-8240-Vacuum-Desoldering-Iron/dp/B008DJRYIG/ref=sr_1_3?ie=UTF8&qid=1457216215&sr=8-3&keywords=desoldering+iron
Offline hKing
« Reply #6 on: Sun, 06 March 2016, 04:10:46 »
Ordered one of those, thanks!
Offline appleonama
  • Trollo en USA
« Reply #7 on: Sun, 06 March 2016, 04:13:10 »
I highly recommend you DO NOT  use a desoldering iron on the tiny led power holes. Reason is if you are a newbie you are going to apply heat for longer than needed and you might damage the pcb
I actually bought a weller desoldering iron and it could not do the job. you need that solder sucker i posted and make sure you get a good seal with the flexible silicone tip.
« Last Edit: Sun, 06 March 2016, 04:20:46 by appleonama »
Offline hKing
« Reply #8 on: Sun, 06 March 2016, 05:22:19 »
Alright, I cancelled my order.
The problem with your product is that the plastic tip is heat resistant only up to 350 degrees. That is my desoldering temperature ...
It is also a bit expensive (but at lease I found a source where I can buy that in Germany...)
I think I can't get a complete seal because the holes are so damn tiny and of course you need some space for the solder iron...
« Last Edit: Sun, 06 March 2016, 05:42:00 by hKing »
Offline flabbergast
« Reply #9 on: Sun, 06 March 2016, 09:55:58 »
The way I desoldered the SIP sockets (although I think this is not a very "safe" method) is to heat up a solder joint and gently "bump" the keyboard - the SIP socket should just fall out (the switch being opened in advance of course). It's easier to remove the solder from the pad afterwards.
Offline hKing
« Reply #10 on: Sun, 06 March 2016, 11:01:29 »
The Winkeyless top place doesn't have cutouts to open the switch. Your method isn't working...
I just ordered the desoldering sucker appleonama suggested. This one has a very flexible tip, I hope that's the solution to my problem ...
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #11 on: Sun, 06 March 2016, 13:10:13 »
I'm having an issue w/ getting an LED to work after desoldering and resoldering it on my Pok3r as well. How much do those SIP sockets go for?
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
Offline Thumper_
  • Spend all my money.
« Reply #12 on: Tue, 08 March 2016, 06:34:21 »
Zeal sells long legged for ~10$ per 120.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #13 on: Tue, 08 March 2016, 10:17:47 »
Ah I just read something that says you have to modify your switches to fit them. This true?
Offline rpeterclark
  • RPTR ❌
« Reply #14 on: Tue, 08 March 2016, 12:21:00 »
No, you just need to open the switches to put them inside. This thread has a good description: https://geekhack.org/index.php?topic=51792.0 . Some people leave the SIPS in the black sleeve, some people remove the SIPs from the sleeve entirely (my preference), but you shouldn't need to make any changes to the switches themselves.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #15 on: Tue, 08 March 2016, 13:40:30 »
Dang. I didn't realize this.
I'm not sure what I should do with my board. I'm thinking about putting heavier springs and lubing my Pok3r. I'd probably be better off doing a custom at this point... though I do want to at least lube this guy.
Do you have any tips for simply desoldering / resoldering the LED's without damaging the board? I had a hell of a time on only a few of them.
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #16 on: Tue, 08 March 2016, 13:43:29 »
Just heat up the hole for the sip socket and pull it out, then clean out the rest, as suicidal orange explained. Soldering wick is better than soldapult on this imo.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #17 on: Tue, 08 March 2016, 16:59:35 »
Good to know. Forunately, I added some to my order which is arriving tomorrow.
Offline sinusoid
  • fd > ESC
« Reply #18 on: Wed, 09 March 2016, 03:04:50 »
When I have to desolder lots of pins, I use a 'wet' desolder wick to make a thermal bridge between them and hotair it, then pull the part out. If there's stuff I don't want to heat up near it, I insulate it off with kapton tape and/or alu foil.
@flabbergast
Ahh, the good old student method for scavenging parts. Although in my stories, there were ovens or ceramic stovetops, and there was no 'gentle' part. But it works, kinda.
Offline phosphoric
« Reply #19 on: Tue, 15 March 2016, 16:30:20 »
+1. removing/inserting leds is much easier with solder in a liquid state than attempting to remove all of the solder. as a college student, i've found this to be the best method of adding or removing leds (adding leds i.e. pre-filled holes like in the pok3r). lower your temp and just heat the solder and push the led in/pull it out with your iron still on the solder.
Let's get this straight. There is nothing cool about keyboards we're all lame as fk.
speak for yourself
