Author Topic: Soarer's Converter: Pre-made or Home-made  (Read 4434 times)
Offline y11971alex
  • Looking for Toronto meetup
« on: Sat, 05 March 2016, 17:13:22 »
http://www.ebay.ca/itm/NEW-XT-AT-to-USB-Soarers-Converter-Remapping-Macros-NKRO-Support-IBM-Model-F-/281476427201?hash=item41894d6dc1:g:U4cAAOSwDN1USZL-
I'll be needing one of these in the near future.  This item as it stands is about CAD$60 shipped, but if I made the converter according to the guidelines on this forum, all the materials plus shipping combined would also come up about $60.
Which should I go with?
Re: Soarer's Converter: Pre-made or Home-made
« Reply #1 on: Sat, 05 March 2016, 17:30:37 »
Huh? A Teensy is about $22 delivered to my door in Atlanta, $17 if I buy it at Micro Center. And a mini-USB cable is about $2. I know Canadian shipping is expensive, but not that.
Are you talking about buying a soldering iron and all the basic supplies?
- D Trump 2026-09-28
Offline y11971alex
« Reply #2 on: Sat, 05 March 2016, 17:33:07 »
Huh? A Teensy is about $22 delivered to my door in Atlanta, and a mini-USB cable is about $2. I know Canadian shipping is expensive, but not that.
http://www.ebay.ca/itm/Teensy-2-0-with-Pins-/321646889182?hash=item4ae3a608de:g:LGMAAOSw1vlUvlWh
A Teensy is CAD$35 + $12 shipping, and it seems I still need the breadboard and a female 5-pin DIN to get the wiring through from the original cable.
« Reply #3 on: Sat, 05 March 2016, 17:44:49 »
A breadboard is entirely optional. I buy Teensies direct from pjrc https://www.pjrc.com/store/teensy.html
I would mount the Teensy internal and forget all the messy cable connections, but then I can do it the other way, too:
https://geekhack.org/index.php?topic=58941.msg1348717#msg1348717
Finding the female receptacle for the DIN plug is a pain, I have spares of both kinds (face-mount and cable-end) but it would probably cost $10 to ship it to you from the US.
Offline y11971alex
« Reply #4 on: Sat, 05 March 2016, 17:52:18 »
I'm not entirely comfortable with working with soldering irons, which is why I want to do it on a breadboard with pins.  It would be nice if someone could invent metallic superglue!
« Reply #5 on: Sat, 05 March 2016, 18:45:17 »
Solder is wonderful because you can re-melt it and take it apart with no damage to anything - if you are careful and/or lucky.
