Author Topic: [Amazon] 700w power supply $40  (Read 3067 times)
Offline appleonama
  • Trollo en USA
Re: [Amazon] 700w power supply $40
« Reply #1 on: Sat, 05 March 2016, 23:12:51 »
wth
the price says 78 but the option shows 40
Offline asdfjkl36
  • blue shirt guy
« Reply #2 on: Sat, 05 March 2016, 23:15:05 »
Mine shows it perfectly fine
Offline klennkellon
  • I like bottoming out
« Reply #3 on: Sun, 06 March 2016, 03:05:47 »
while it's probably a decent unit, if your system needs 700w you should invest in a higher end PSU like EVGAs GS, GQ, or G2 series.
Offline appleonama
  • Trollo en USA
« Reply #4 on: Sun, 06 March 2016, 03:16:48 »
psu's are over marketed
no one needs more than 700w good or bad
I run 4790k
2 780ti's
and I never exceed 650w
