Author Topic: What's on your Alps board?  (Read 4664 times)
Offline bcredbottle
« on: Tue, 08 March 2016, 14:27:02 »
Hi guys,
I would like to make a mod set for Alps boards, but Alps boards use a variety of mods. Would you mind please filling out this one-question survey? I will release the results for the benefit of all Alps capmakers.
Please let me know if I'm missing anything or any entries are duplicative.
Survey: What's on your Alps board?
Current results:
Most of the "other" votes are Dell AT101w. Oops. Forgot to add that.
« Last Edit: Wed, 09 March 2016, 09:30:07 by bcredbottle »
Offline BlueNalgene
Re: What's on your Alps board?
« Reply #1 on: Tue, 08 March 2016, 14:29:18 »
Responded
Offline bcredbottle
« Reply #2 on: Tue, 08 March 2016, 14:35:20 »
Responded
Thank you! You guys have no idea how helpful this is!
Offline bcredbottle
« Reply #3 on: Tue, 08 March 2016, 15:08:22 »
Wow I shouldn't have made all those AEK mods :( lol
Offline njbair
    • nickbair.net
« Reply #4 on: Tue, 08 March 2016, 19:37:11 »
Filled out. I use my Alps 60% boards most of the time these days (Alpine Winter & AEKII caps), but I pull out the Filco Zero with Tai Hao doubleshots at least weekly, for any kind of arrow-heavy work.
My boards:
Offline G-Dubs
« Reply #5 on: Wed, 09 March 2016, 09:27:52 »
Filled it out. It'll be interesting to see the final results.
« Last Edit: Fri, 11 March 2016, 14:23:03 by G-Dubs »
KUL ES-87 MX Red || KBP V60 Matias Linear || KBP V60 Matias Quiet Click || Varmilo VA87MR Gateron Black || Leopold FC210P MX Black
Offline StormyMonday
« Reply #6 on: Tue, 15 March 2016, 19:55:49 »
Responded ... curious to see where this goes.
Offline Zorberema
  • IG: @ZorbCaps
« Reply #7 on: Wed, 16 March 2016, 05:00:51 »
I'll be using my AEK keycaps on my new cluboard build; do you already have molds for the mods? I've been planning on molding them myself; would you be willing to share how you managed to get all the air out of those super long stems?
Offline bcredbottle
« Reply #8 on: Wed, 16 March 2016, 13:12:19 »
I don't have stem bubble problems bc I prepour my stems and let the stem fully cure before pouring my final shot of resin. But that may not work for everyon; I like my stems to be a different color from the underside.
You can also just add a vent to the tip of the stem either by boring through the cured silicone with a 14ga syringe, or by supergluing an upside down pointed  toothpick to the tip of the stem on the master key. The only disadvantage to this is that you'll have to sand down the little nub that's left after you demold and snip the vent sprue off.
« Reply #9 on: Wed, 16 March 2016, 13:13:54 »
Boated.
Offline SJHL
« Reply #10 on: Wed, 16 March 2016, 16:57:19 »
Done. For my main Alps board, I've been using Focus 2001 Alphas and Alpine Winter Modifiers for the time being. I'm also using IBM 5140 keycaps for my other keyboard.
Offline alienman82
« Reply #11 on: Wed, 16 March 2016, 19:19:05 »
removed.
« Last Edit: Thu, 01 March 2018, 15:50:44 by alienman82 »
