Author Topic: Mic Pre-Amp  (Read 2784 times)
Offline SCTony
Mic Pre-Amp
« on: Tue, 08 December 2009, 19:55:04 »
I bought a microphone on eBay and now I find I need a pre-amp. The mic is a Sony electret cond. stereo model ECM-MS907. I found a Visivox pre-amp on ebay for about $30. Mostly I record nature/ambient outdoors (like rain/thunder/boats/birds/planes) and maybe a keyboard or two in the future. :happy:  I have been using my camera, which records very well (to me). I will be recording onto a Cowon iAudio 7 pmp for now. I am also considering building a pre-amp from a kit, but that will take some time to complete. Any suggestions/advice for a reasonably decent/low-cost solution or any comments on the Visivox? Thank you so much.
IBM PC-AT Model F ;  Model M-
    1391401 Aug 89, 92G7453 Nov 95, 42H1292 Jul 97
Compaq KB-9963 (rubber dome);
Cherry MX-SPOS:typing:
Offline ricercar
  • mostly abides
Mic Pre-Amp
« Reply #1 on: Tue, 08 December 2009, 21:02:34 »
I'd suggest you don't get the Visivox. You need two mono preamps like that one to record in stereo.
Sony mics tend to be made for Sony recorders. I've had a few of each. Your Sony mic has a 1/8" stereo plug, which may limit your choices, unless you're comfortable recording in the wilds with seven inches of adapters hanging off a two inch MP3 recorder. To avoid adapters, I've tended to solder my own plugs on cords when I have a portable recording rig.
I've never seen a semi-pro mic preamp with a 1/8" stereo mic input. They tend to have 1/4" (unbalanced) plugs or 3-pin amphenol (balanced) connectors. I can't tell what kind of input jack is on the Cowon, or if it has the ability to control input level.
If the Cowon doesn't have recording or input level adjustment, then somewhere between mic and recorder you need a control that lets you change the volume of each input signal. Instead of buying a pair of preamps, You may wish to buy a mixer with built-in preamps. When my kids aren't climbing all over me I'll look up a few examples.
« Last Edit: Tue, 08 December 2009, 21:12:52 by ricercar »
Offline SCTony
Mic Pre-Amp
« Reply #2 on: Tue, 08 December 2009, 21:24:13 »
Thanks Ricercar. The Cowon uses a 1/8 inch jack and has some line-in volume control (a choice of 1,2,3,or 4). I was thinking the Visivox was stereo but maybe that's a different model. I appreciate your time.
Offline SCTony
Mic Pre-Amp
« Reply #3 on: Tue, 08 December 2009, 22:05:45 »
Thanks Ripster. Are you satisfied with the Visivox? Are the noise levels low? I haven't gotten to use the mic yet as I barely get a signal without a pre-amp.
Offline ricercar
  • mostly abides
Mic Pre-Amp
« Reply #4 on: Tue, 08 December 2009, 22:14:15 »
I stand corrected.
Offline cb951303
Mic Pre-Amp
« Reply #5 on: Wed, 09 December 2009, 02:17:04 »
If you're looking for a a cheap mic preamp take a look at art tube preamps: http://www.artproaudio.com/default.asp?p_id=4
Filco Zero FKBN87Z/EB
Kensington Orbit K72337US
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Mic Pre-Amp
« Reply #6 on: Wed, 09 December 2009, 02:56:03 »
Quote from: cb951303;140371
He was looking for a microphone preamp, not a microphonic one... :p
OK, seriously now, but would you buy from a company whose website looks like this (scaled down to 50% - that's a 20" UXGA screen here)?
Anyway I think solid state is the way to go here... impedances are rather on the low side.
Offline cb951303
Mic Pre-Amp
« Reply #7 on: Wed, 09 December 2009, 05:21:35 »
Quote from: keyb_gr;140373
huh?
art sells "microphone" preamps (damn good ones) and the website looks good on firefox and chrome. no one cares about how internet explorer views sites. it has its own crippled understanding of standards.
http://pro-audio.musiciansfriend.com/product/ART-Tube-MP-Studio-Mic-Preamp?sku=180581
« Last Edit: Wed, 09 December 2009, 05:24:20 by cb951303 »
Offline itlnstln
Mic Pre-Amp
« Reply #8 on: Wed, 09 December 2009, 07:54:54 »
The site looks fine in IE, too.  I had no problems with it.
Offline SCTony
Mic Pre-Amp
« Reply #9 on: Wed, 09 December 2009, 15:20:48 »
Thanks everyone- yes I got the Visivox. They don't appear very often on eBay (i had a saved search running for a while) so I went ahead and bought it before someone else snagged it. I think it will do what I am looking for. [These MX-SPOS Cherry Browns are nice! :) ]
Offline SCTony
Mic Pre-Amp
« Reply #10 on: Wed, 09 December 2009, 16:57:35 »
Thanks. I wish it was phono level :)
