Author Topic: Hi guys! I'm new here...  (Read 2795 times)
Offline rondg
« on: Sat, 12 March 2016, 22:10:25 »
Hi guys! The breaking of my Razer Blackwidow blue switch keyboard led me here. And boy oh boy, I am glad it broke. It opened my eyes to this wonderful world. Now, I was in search of a replacement keybaord and was considering to buy the Corsair Strafe RGB mx browns, but I do not have the budget to buy one. I searched for other inexpensive alternatives, one click led to another and BAAAM!!! I can build my own keybaord?!? Yes please!!!
I registered so that I can learn stuff from the community. I hope that in time, I will learn enough to contribute to the community.
FYI, I hate my keyboard right now. It's a $5 Japanese layout dome keyboard. I am not Japanese. I hope I can replace this ASAP...  :-[
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hi guys! I'm new here...
« Reply #1 on: Sat, 12 March 2016, 23:12:25 »
Hey there, welcome :) Which keyboard are you planning to build? What kind of switches were you thinking about installing?
Offline rondg
« Reply #2 on: Sat, 12 March 2016, 23:41:17 »
To be honest, I'm not yet sure. I'm thinking of getting the parts from winkeyless, but I really like GON's keyboards. I am a bit worried though because I read that some orders from 2014 are still not yet fulfilled up to now. I am very curious about the Zealio Switches, but I would like to read some more before jumping the gun.
I would like a 104 ANSI, a TKL and a numpad (just because  ;D), but I haven't really thought about what to build first.
Do you have any recommendations?  :)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Sat, 12 March 2016, 23:49:40 »
Good options :thumb:
Filco Majestouch is a solid keyboard. Filco makes a numpad and there is a replacement controller for it to make it fully programmable.
Nothing like a GON or Winkeyless though.
Have you met Topre?
Offline rondg
« Reply #4 on: Sat, 12 March 2016, 23:54:32 »
Have you met Topre?
I have heard about Topre!!! I would like to try one in the future. The Realforce 104UG "High-Profile" looks very appealing, but comes with a high price tag...  :-\
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Sun, 13 March 2016, 00:47:05 »
Oh lawd yes :)) But not nearly as expensive as a GON keyboard
Offline rondg
« Reply #6 on: Sun, 13 March 2016, 03:30:41 »
True dat.. True dat..  :))
But I guess I will also be paying the experience of building a keyboard  ;D
« Reply #7 on: Sun, 13 March 2016, 20:27:25 »
Welcome to Geekhack!
Building a keyboard almost always turns out more expensive than buying one pre-built.  You also need a good soldering iron and lots of patience.
Also note that the Corsair Strafe RGB has a non-standard bottom row, so finding replacement keycaps will be slightly more difficult.
