Author Topic: Hi guys  (Read 8388 times)
Offline tullyvivi
Hi guys
« on: Sun, 13 March 2016, 12:38:14 »
Hi, guys,
My account has been relatively silence since I registered, I think it's time to make more connections with people.
Thanks
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hi guys
« Reply #1 on: Sun, 13 March 2016, 13:19:51 »
Dec. 2014 wow! Welcome  :)
So what keyboard did you wind up with?
Offline tullyvivi
Re: Hi guys
« Reply #2 on: Sun, 13 March 2016, 13:33:17 »
Hi, I had a black widow, then step it up to a 87 Topre, then finally a random TKL (I really need to work on my soldering skill). :)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hi guys
« Reply #3 on: Sun, 13 March 2016, 14:47:32 »
Variable weight Topre 87? Hi-pro?  :eek:
Offline tullyvivi
Re: Hi guys
« Reply #4 on: Sun, 13 March 2016, 15:02:21 »
One variable 87 at work, and one hi-pro 104 at home :). I really began to like them. Although cherry just have so many awesome things you can do
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hi guys
« Reply #5 on: Sun, 13 March 2016, 15:13:54 »
Some people buy a NovaTouch to harvest those cherry mx sliders ;) I'm curious if others have been successful with the cheaper topre clone boards from noppoo or royal kludge. I have no idea how to open up a topre switch unfortunately.
http://imgur.com/a/ry0Nr
Re: Hi guys
« Reply #6 on: Sun, 13 March 2016, 20:42:41 »
Welcome to Geekhack!
Any particular reason for the long break?
What happened to your Blackwidow?
Offline tullyvivi
Re: Hi guys
« Reply #7 on: Mon, 14 March 2016, 12:20:30 »
dem, I almost enjoy looking at small ones like this, small and sweet, but find it less practical to use :(
Offline tullyvivi
Re: Hi guys
« Reply #8 on: Mon, 14 March 2016, 12:28:23 »
Mostly was waiting on parts to assemble them and try out different cherry switches hands-on.
I think the blackwidow is a joy as the first mechanical keyboard for any one really, I loved mine a lot.
After using it for a year or so, I found it to be tiring when you type lots of stuff really fast. Sometimes getting frustrated that it's not so "energy-efficient", but this is why its unique.  Mx blue is just one of the kind that anyone has to try out. Also, cleaning blackwidow is a ***** and it gets dirty pretty dem fast. So I passed on to its next owner.
Re: Hi guys
« Reply #9 on: Tue, 15 March 2016, 01:04:45 »
That's fair enough.
Many have had a Blackwidow that self-destructed in some way.  Others have used their for years without issue.
