Author Topic: Filco Majestouch 2 repair  (Read 72180 times)
Offline adrock
« on: Mon, 14 March 2016, 18:24:55 »
My MJ2 with browns has started playing up, keys not registering or registering multiple key presses, mostly down the left hand side.
it's over a year old; is it possible to pay to get it repaired or looked at? I've tried giving it a thorough clean but no luck.
Offline wsjudd
  •  Moderator
    • The Keyboard Company Blog
Re: Filco Majestouch 2 repair
« Reply #1 on: Fri, 18 March 2016, 20:38:54 »
The obvious question is 'have you tried it in other PCs to make sure it's not a driver / PC / USB issue?'
Otherwise, if you bought it from The Keyboard Company, why not get in touch with our support? If you write your issue on http://www.keyboardco.com/contact.asp, we'll look into it once we're back on Monday. Otherwise, let me know your email address, and I'll send an email on your behalf.
Cheers,
Will
Blogs & Social Media
