Author Topic: Why do most low-end keyboards have the same ugly font on their caps?  (Read 21760 times)
Offline Rad
I always see the same ugly font on Pok3r keyboards and other entry level mechs. I'd link a picture, but I just ate.
Is there some kind of patent issue with key cap fonts and the font in question is cheap? What gives?
Just because you don't want to spend a lot of money doesn't mean you should have to deal with dry heaving every time you look at your fingers.
Offline nmur
  • ಠ_ಠ
Re: Why do most low-end keyboards have the same ugly font on their caps?
« Reply #1 on: Mon, 14 March 2016, 19:41:51 »
I think they're trying to tap into the g4m3r market by having futuristic/technical looking fonts
most people seem to discover mechs through gaming related media
Offline Rad
« Reply #2 on: Mon, 14 March 2016, 19:43:23 »
Yeah I go to my local robot shops, and it's all Corsair and Razer. Flashing lights everywhere. They should make a keyboard that makes noises. I want to hear a clown horn every time I press a key.
Offline jacobolus
« Reply #3 on: Mon, 14 March 2016, 20:02:47 »
You can get a better looking keyboard from the 80s for about $30–40 shipped on ebay, plus another $5 for an adapter.
Offline Coreda
« Reply #4 on: Mon, 14 March 2016, 20:33:23 »
Bank Gothic isn't ugly per se. The Poker 3 though has non-center align legends unlike the previous versions, which don't suit it at all. Haven't seen the typeface used for other boards.
Offline kekman
  • quit life
« Reply #5 on: Mon, 14 March 2016, 22:22:06 »
I always see the same ugly font on Pok3r keyboards and other entry level mechs. I always see ugly fonts on all keyboards
blanks master race
Offline effectiveduck
« Reply #6 on: Mon, 14 March 2016, 22:24:47 »
The fonts could be cheaper to licence.
Offline Rad
« Reply #7 on: Mon, 14 March 2016, 22:28:32 »
blanks master race
I use blanks too. Sometimes I see boards that have some caps with white font and other caps with black font. Two different font colors on the same board. Whaaaat?
Offline appleonama
  • Trollo en USA
« Reply #8 on: Mon, 14 March 2016, 22:59:01 »
Gaymer aesthetics bro gotta look MLG ESPORTs
Offline alexjd99
  • oozing through the cells of one's own construction
« Reply #9 on: Mon, 14 March 2016, 23:05:15 »
r u even 1337? if u wur a 1337 g4m3r u wud get y the fonts luk k001
Offline klennkellon
  • I like bottoming out
« Reply #10 on: Mon, 14 March 2016, 23:21:01 »
What? You don't want your keyboard to look like a prop from a 1970's sci-fi porno parody film?
Offline alexjd99
« Reply #11 on: Mon, 14 March 2016, 23:31:00 »
My keyboards are props from '70's sci-fi porno parodies
get on my level
Offline klennkellon
« Reply #12 on: Mon, 14 March 2016, 23:40:33 »
get on my level
mine was more than just a prop in one of those.
Offline Rad
« Reply #13 on: Mon, 14 March 2016, 23:43:28 »
get on my level
Talk about a dirty keyboard.
Offline kekman
  • quit life
« Reply #14 on: Tue, 15 March 2016, 00:15:15 »
antique value!
Offline klennkellon
« Reply #15 on: Tue, 15 March 2016, 00:25:56 »
**RARE** Vintage CLICKY IBM keyboard used in 1970 thriller "NAZI LOVE ISLAND" $499
« Reply #16 on: Tue, 15 March 2016, 01:20:10 »
Maybe they have realised that the majority of mechanical keyboards go to keyboard enthusiasts, who usually swap keycaps anyway.
So why spend extra money on keycaps and raise the price of a keyboard if you're just going to remove the keycaps anyway.
Put cheaper keycaps on, brings the price of the keyboard down.
Offline saxophone
« Reply #17 on: Tue, 15 March 2016, 05:13:30 »
Same fonts are used cause they use the same OEM to produce the caps.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #18 on: Tue, 15 March 2016, 08:27:16 »
Same reason why people put ugly ass decals and spoilers on their car.
They think it looks cool (Some even think it will make the car faster / type faster)
Classy > l33t / d0pe
IMO
But clacks do make you type faster. proven fact. so don't even. Because I cant even.
Offline y11971alex
  • Looking for Toronto meetup
« Reply #19 on: Tue, 15 March 2016, 09:09:27 »
Lack of creativity can be thought of as a form of ugliness too, such as the sans-serif fonts used by IBM on all their keyboards to date.
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #20 on: Tue, 15 March 2016, 11:34:04 »
I think most boards at truly entry level are judged to be used by gamers and not professionals and they like that odd look.   That said you really think the font on the pok3r is ugly? I think it's fairly normal honestly.
https://i.ytimg.com/vi/8wjW-Or1jg8/maxresdefault.jpg  (Stock pok3r)
What i consider ugly gamer fonts is something like this.
http://images.anandtech.com/doci/7911/RZBWU_11.JPG  (Razer BlackWidow)
Or
http://img.dxcdn.com/productimages/sku_328860_1.jpg  AULA Demon King
That said i can't really consider the pok3r an entry level board either.  Entry level is like CM QFR,Spyder Noppoo,Ganss etc.  It may not quite be endgame for most but it's definitely not an entry level board either.
Someone already mentioned earlier also it may be due to cost since several use the same OEM for caps and most know people will likely replace the keycaps anyways in the long run.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline Rad
« Reply #21 on: Tue, 15 March 2016, 11:49:56 »
It's called ninja font or something? Booooo.
« Reply #22 on: Tue, 15 March 2016, 11:54:27 »
On the pok3r or the Razer/AULA boards?
The pok3r is bank gothic i believe (Which i don't mind though i will admit i prefer the look of the font on my Realforce)
The Razer/AULA though ...hurt my eyes.
Offline FoxWolf1
  • 154
« Reply #23 on: Tue, 15 March 2016, 12:17:04 »
Ehh, appearance is just a personal preference. Not everyone likes the same things, and that's fine.
Also, not everyone obsesses over the appearance of their keyboard the way many "enthusiasts" do. Some buyers care more about price and capabilities/features than looks, and if they don't care, the companies that cater to them will just use whatever caps the cheapest OEM has on hand.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #24 on: Tue, 15 March 2016, 13:50:50 »
I'm fine with most simple non-serif fonts. Chicony used a pretty nice one, Key Tronic's was pretty ugly.
Everything is better than that revolting font on the AEK and AEKII (and they're not even placed correctly Oo ).
Offline appleonama
  • Trollo en USA
« Reply #25 on: Tue, 15 March 2016, 13:52:30 »
Ugliest font to date is the black widow
Offline chyros
  • a.k.a. Thomas
« Reply #26 on: Tue, 15 March 2016, 14:07:31 »
Everything Razer make is vulgar and tasteless xD .
Offline klennkellon
« Reply #27 on: Tue, 15 March 2016, 17:45:18 »
the first generation black widow was my first mechanical board, I have a soft spot for it  :-[
« Last Edit: Tue, 15 March 2016, 17:55:09 by klennkellon »
Offline piemancoder
« Reply #28 on: Tue, 15 March 2016, 20:21:53 »
We need a comic sans keycap set. Everyone would love that, right?
Yoda grammar best has
Offline klennkellon
« Reply #29 on: Tue, 15 March 2016, 20:27:31 »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #30 on: Tue, 15 March 2016, 20:50:56 »
I'm probably not going to purchase a keyboard that looks like it could be used as a stencil for keyboard graffiti.
keyboard graffiti.. I think my life is missing keyboard graffiti..
This is not a stencil.
Offline kekman
  • quit life
« Reply #31 on: Tue, 15 March 2016, 23:53:08 »
it's modern art, go sell it for 10,000,000 on ebay
« Reply #32 on: Wed, 16 March 2016, 04:34:39 »
This is a thing!
Looks too much like Comic Sans at smaller sizes though.
Offline kekman
  • quit life
« Reply #33 on: Wed, 16 March 2016, 05:23:03 »
I'm pretty sure the Deck Hassium uses Papyrus
Offline Fiery
  • Click Clack Clock and a nice Thock
« Reply #34 on: Wed, 16 March 2016, 05:32:13 »
I personally like the Pok3r font, But the "gamer" fonts on the razer are atrocious. And the LED's just make them a million times worse.  :confused:
Blanks just look nicer in my opinion.
*EDIT* Why do you consider the Pok3r a entry level mech keyboard?
« Last Edit: Wed, 16 March 2016, 05:37:48 by Fiery »
TP4 fanboy
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #35 on: Wed, 16 March 2016, 07:34:44 »
If that keyboard was mine I would keep it in a glass case! :p
Offline appleonama
  • Trollo en USA
« Reply #36 on: Wed, 16 March 2016, 10:16:23 »
Reported I will have no sympathy for razer lovers
Offline chyros
  • a.k.a. Thomas
« Reply #37 on: Wed, 16 March 2016, 10:41:44 »
I prefer legends that make no sense to blank caps tbh. Makes it even more mysterious, especially on weird layouts. Terminal keyboards are cool like that.
Or legends that are just plain weird. Like that "URINE" key on the hospital keyboard that got posted a while back.
« Reply #38 on: Wed, 16 March 2016, 14:53:07 »
The only reason i like blanks on some of my boards and the very stealth look of the Realforce is it's beyond comical watching my wife try to type.
Offline Rad
« Reply #39 on: Wed, 16 March 2016, 15:22:00 »
Surf Skate the web!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #40 on: Wed, 16 March 2016, 15:53:22 »
Surf Skate the web!
huehue
Offline falkentyne
« Reply #41 on: Wed, 16 March 2016, 15:55:59 »
Because the same OEM often makes the keycaps for several manufacturers.  Thus the same font is used
Offline Red October
« Reply #42 on: Wed, 16 March 2016, 17:07:22 »
My IBM 6112884 has a beeper in it that can be set to "stupid-loud" if you want using the keyboard to be a tortuous exercise.  Uncomfortably loud even with my Beyerdynamic headset on.
I for one miss the days when, if you wanted a product to look "Hi-tech", you slapped OCR-A or Westminster on it and called it a day.
Offline ileben
« Reply #43 on: Wed, 16 March 2016, 17:31:06 »
Personally I find the stock Pok3r font just as atrocious as the one on Razer. They are both targetting the gamer audience very clearly.
EDIT: It's even called "Pok3r" and not Poker. Come on...
« Last Edit: Wed, 16 March 2016, 17:33:11 by ileben »
RF 87 55g (silenced) | FC660C (silenced) | Unicomp Ultra Classic | Filco MJ2 Brown | Matias Mini Quiet Pro
Offline saxophone
« Reply #44 on: Wed, 16 March 2016, 18:28:01 »
Wow that AULA is sooooooo FAKE.
A real AULA looks something like http://www.aliexpress.com/item/AULA-Professional-Gaming-Keyboard-Black-Mechanical-Keyboard-87-Keys-Red-Switch-With-Multimedia-USB-Wired-Laptop/32626501622.html **** like a Daemonic Aegis ready to deflect the beams of suns blinding light from your moms basement at any moment.
Offline piemancoder
« Reply #45 on: Wed, 16 March 2016, 18:33:28 »
My eyes hurt.
Offline ander
  • I type, therefore I am
« Reply #46 on: Wed, 16 March 2016, 20:32:56 »
Flashing lights everywhere... They should make a keyboard that makes noises. I want to hear a clown horn every time I press a key.
LOL—hawnk hawnk!
But then why not use some of the nicer fonts with GPL or GNU free-use licences?
How many subsequent retro sci-fi porn videos have they inspired? That's what I want to know.
To answer the OP: Maybe they doll up these boards to distract people from how mediocre they are as, you know, input devices.
Offline Rad
« Reply #47 on: Wed, 16 March 2016, 22:22:30 »
That's one of the classiest, subtle keyboards I've ever seen. I like that two people can use it at once. You know, for when that happens.
Offline ika
« Reply #48 on: Wed, 16 March 2016, 22:24:09 »
****, two player co-op used to be the best. you must be young.
Offline Rad
« Reply #49 on: Wed, 16 March 2016, 22:26:28 »
Back in my day, a keyboard only cost a nickel.
