Author Topic: Why no context menu keys??  (Read 1846 times)
Offline steelcity
« on: Fri, 18 March 2016, 10:31:13 »
Why do some manufacturers use a second windows key and leave off the context menu key?  That is a deal breaker for me as I am constantly using the context menu key in Excel.  I have had a number of Ducky keyboards and I just couldn't get over the lack of a context menu key so I am planning on selling them all in the very near future.  Why would you ever need a second windows key?  It just seems crazy to me.
I finally found a board I love in the FC900 that meets all of my criteria (full size, non-backlit, context menu key, navy pbt, windowed caps, scrlk, num keys), except the switches.  So I am planning on swapping the switches on my FC900s with 65 G purple Zealios and 67 G purple Zealios to see which I like best.
I also have a Ducky Taiwan Edition 45 G uniform Realforce coming today that does have the context menu key, so maybe I will end up becoming a Topre fanboy, who knows?  I've never used Topre before..
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
Re: Why no context menu keys??
« Reply #1 on: Fri, 18 March 2016, 10:38:53 »
Topre is life.
But, you know you can remap keys and if you really wanted to you could buy different controllers for the boards.
You could also probably buy a phantom PCB and a nice Aluminum case form mechanicalkeybords.com then make your dream board.
All customizable to your liking.
« Reply #2 on: Fri, 18 March 2016, 10:48:08 »
The FC900 series are awesome. My plan was to swap out the stock reds with clears but instead I just kept using it and am now used to it.
Offline Bromono
  • Wanabe Cicerone
« Reply #3 on: Fri, 18 March 2016, 10:56:08 »
I missed the fullsize part. Ignore me.
I am sure you could still probably get another controller but the lack of custom full sizes is sad =(
60% and TKL seem to be the go to for everyone.
Luckily Topre has same amazing cheap full size boards.
I think you would enjoy the Type Heaven or the new Ducky version.
Offline steelcity
« Reply #4 on: Fri, 18 March 2016, 11:34:56 »
the problem with remapping keys is that my work pc is locked down and I cant use sharpkeys or the like.  and on a normal ducky the Fn key is where the Contect Menu key should be, and you can't remap a Fn key.
I have the ducky topre 45g coming today, so maybe I will like that one.   if not, the fc900 with browns is great, and when I mod it with 65 or 67 zealios I am thinking it will be even better!
