Author Topic: Seeking advice for restoring faded red double shot keycap  (Read 4479 times)
Offline lot_lizard
« on: Sat, 19 March 2016, 18:11:07 »
I have a rare IBM 3279 beamspring with a faded red double shot that is part of the secondary panel to control the legacy console itself.  It runs off a separate controller with a completely independent cable coming into the board.  I was just curious if anyone had suggestions for bringing the bright red back.  I would sacrifice texture for color if the results could be excellent.  Thoughts welcomed
Re: Seeking advice for restoring faded red double shot keycap
« Reply #1 on: Sat, 19 March 2016, 18:28:55 »
Maybe retrobrite?
Offline lot_lizard
« Reply #2 on: Sat, 19 March 2016, 18:39:38 »
I should have mentioned...  I've tried all the conventional methods.  This is actually faded on the surface, and not a film.  Afraid the only real option is "cutting" into the surface with either chemical or abrasive, but there really hasn't been much information on any of those attempts that I can find.  All poor man's testing (water buoyancy and acetone) would suggest this is PBT plastic
Offline Pemdas
« Reply #3 on: Sat, 19 March 2016, 18:41:44 »
I don't know if this would help in your case but I remembered seeing a post about someone sand blasting keys to get rid of the shine. Maybe you can use a similar method to remove the faded layer?
Here's a link to the image gallery
imgur.com/gallery/4eYLT
Offline lot_lizard
« Reply #4 on: Sat, 19 March 2016, 19:00:37 »
Actually...  This is very clever, and something I hadn't even consider using on plastic.  I have a blaster cabinet, and a few mediums on hand to experiment with, along with some PBT keycaps from a Wheelwriter that I could practice on.  I would still welcome other thoughts, but this would be hard to beat I think.  Thanks again
Offline Pemdas
« Reply #5 on: Sat, 19 March 2016, 20:18:51 »
Glad I could help :)
Also, here's the original deskthority thread
https://deskthority.net/workshop-f7/keycap-sand-blasting-t12946.html
Probably has a lot more info than the Imgur gallery.
Offline appleonama
  • Trollo en USA
« Reply #6 on: Sat, 19 March 2016, 20:57:27 »
just drop it into some paint thinner 10/10
Offline lot_lizard
« Reply #7 on: Sun, 20 March 2016, 15:09:38 »
The results...  I had the advantage of having a completely flat top, and decided to wet sand using 400, 600, 1000, 1500.  I originally anticipated that I would sandblast to just to texturize at the very end (and might still) but wanted it as flat as possible before I did.  The UV fade was deeper than expected, and I might just pass on the additional texture since the 1500 leaves an unpolished look and this cap is literally irreplaceable
« Reply #8 on: Sun, 20 March 2016, 17:00:25 »
Now hit it with a UV protecting sealant so you don't run into it fading again.
« Reply #9 on: Sun, 20 March 2016, 20:48:54 »
That looks great, considering where you started!
Offline lot_lizard
« Reply #10 on: Sun, 20 March 2016, 21:15:57 »
Appreciate that...  I was pleased.  I finally worked up the courage to completely tear this one down, clean, and add the xwhatsit controller and solenoid driver.  I took quite a few pictures along the way and will write something up in the coming week (or so)... After I wire up the lamps at the top of the board for capslock, numlock, and the "Lamp Test" switch.  The beamspring really is a fun animal. I have a couple, and this one has always been my favorite for layout and appearance.
Re: nubbinator...  Great idea on the UV sealant
« Reply #11 on: Mon, 21 March 2016, 00:25:52 »
Making stuff together would be a great place for a restore log :)
