Author Topic: [GB] ZZ96 v2 r2 (replacements in progress)  (Read 368531 times)
Offline LunarisDream
Re: [GB] ZZ96 v2 r2 (status: production complete, shipping soon™)
« Reply #350 on: Fri, 08 July 2016, 03:50:45 »
I'm still so happy I'll get a full keyboard in about 2-3 months and it took 15 months for Hyperfuse to get to me.
I can't wait for this thing!
Haha, better than the Hyperfuse that was supposed to get to me... USPS lost it.
I've probably just missed it somewhere in the thread (or the previous one), but where do the indicator LEDs go?
Capslock and numlock? They're in-switch.
« Reply #351 on: Fri, 08 July 2016, 06:54:53 »
Offline TerryMathews
« Reply #352 on: Fri, 08 July 2016, 08:32:38 »
Nice. Looks like it could be mine.
Had a question on the indicator LEDs though. How does the board know which keys are num lock and caps lock, or is it just set to the traditional location? Is there any provision to put a scroll lock led in?
Offline reggalicious
« Reply #353 on: Fri, 08 July 2016, 09:27:35 »
Oops
I got a silver case!  Holy **** this thing looks amazing.
« Reply #354 on: Fri, 08 July 2016, 10:55:28 »
Not that I recall. I don't think the PCB is equipped to set any key's LED as an indicator one. I will have to check the PCB to be sure.
« Reply #355 on: Fri, 08 July 2016, 12:18:19 »
Now we're speaking the same language... if you could check for me I'd appreciate it.
Offline breitling
« Reply #356 on: Fri, 08 July 2016, 13:20:21 »
Ooooh Those cases look fantastic.
Offline NguyenBaoLong
« Reply #357 on: Fri, 08 July 2016, 15:09:55 »
Why i cant see none of darkblue one bro T T its not anodized yet?
Offline ipley
« Reply #358 on: Sat, 09 July 2016, 09:30:11 »
Good. bro.
color is very nice
Offline Pieminister
« Reply #359 on: Sat, 09 July 2016, 11:52:19 »
These look fantastic! Thank you so much for all the work.
I wanted to double check with you guys whether I have everything I need for my first build
- PCB, case and stabs as part of this GB
- zealios, LEDs and SIP sockets are on the way
- soldering station
- still need to buy solder
- key caps (PBT4 with retro GMK hopefully soon)
Anything I am missing?
« Reply #360 on: Sat, 09 July 2016, 14:48:51 »
It appears that this is the color of "dark blue" despite the image given to me (that I organized in the color selection chart).
=https://geekhack.org/index.php?topic=82124.msg2187967#msg2187967This comment from the AMJ96 thread commented on this but I wasn't sure if it would happen here.
If this is not acceptable (the color difference is very drastic), please send me a PM and we'll try to work out a solution.
- soldering station
Yeah, you're all good. I highly recommend a wire sponge for scraping off solder/flux from your iron.
Oh, you'd also need a miniUSB cable.
Offline boo
« Reply #361 on: Sat, 09 July 2016, 15:26:58 »
- soldering station
Have you seen the color yourself yet? I am hoping that this is not true.
« Reply #362 on: Sat, 09 July 2016, 15:33:20 »
I have. This is supposed to be "deep blue" but it does not match the one in the color options.
There was only one deep blue order in the entire buy, NguyenBaoLong's breitling's. It's easy to get the name mixed up with dark blue, of which there were significantly more orders.
« Last Edit: Sun, 10 July 2016, 00:48:19 by LunarisDream »
« Reply #363 on: Sat, 09 July 2016, 16:19:23 »
My order is through a Friend in China and ít sent directly to Huan.But i cant contact with the designer of the case through some issue of contact.So confuse about the color until now.The dark blue should be similar with the black color right? Or it gonna be like the Cyan.If it like the Cyan it would be horrible
« Reply #364 on: Sat, 09 July 2016, 20:07:14 »
There was only one deep blue order in the entire buy, NguyenBaoLong's. It's easy to get the name mixed up with dark blue, of which there were significantly more orders.
Damn, that's a beautiful blue if the person who was supposed to get it doesn't want it let me know. I'll take it.
Offline Rob123
« Reply #365 on: Sat, 09 July 2016, 21:32:24 »
Just to clarify, is the linked picture deep blue or dark blue?
Offline Atredl
« Reply #366 on: Sat, 09 July 2016, 23:05:05 »
I'm confused too. Is this supposed to be deep blue or dark blue?
Offline Elaeagnifolia
  • Click Quack.
« Reply #367 on: Sat, 09 July 2016, 23:09:33 »
The image that Lunaris linked (https://i.sli.mg/EBdkqM.jpg) is Deep Blue, not Dark Blue. I clarified with him a couple hours ago.  :thumb:
Offline Atredl
« Reply #368 on: Sat, 09 July 2016, 23:11:50 »
In that case, ignore my PM Lunaris.
« Reply #369 on: Sun, 10 July 2016, 02:01:35 »
Most of the colors are accurate, but there are three that I'm not very happy about. One is the deep blue, which is Breitling's, the second is dark blue, and the last is light gray.
This is what I can capture with my phone's camera for dark blue. It's not entirely accurate, but the blue part is so subdued that it is very hard to capture.
The light gray looks very silver-y (not as light) and not nearly as dark as the colors pic. The cases reflect light due to the anodizing and appear to be lighter than they are, but it's still lighter than the light gray here. The designer told me this was because of the change in factories - all of my pictures are color samples from the old factory. But this isn't what happened with the case. The deep blue was a factory problem, but that's not the case for dark blue.
Dark blue is lighter than what it's supposed to be due to my mistake. The color I placed the order for "dark blue" was "灰蓝", because I thought that was the appropriate option. However, I just found out that the "dark blue" in here is actually "黑蓝". "灰蓝", what I placed the order for, was "gray blue", and the color that we wanted (and pictured) was "黑蓝", or "ink blue". So we got a batch of "gray blue" when we wanted "ink blue". This is my own fault, and I will take full responsibility.
Light gray is in the same boat due to the same mistake on my part. I reported "浅灰" (light gray), but the picture from here is actually "钛灰" (titanium gray). This is why it appears to be much lighter than the colors pic.
Comparison between light gold, silver, light gray, and gray blue: http://sli.mg/a/PMICGl
To summarize things, the colors were in the color pic mislabeled as dark blue and light gray are actually ink blue and titanium gray. The orders were placed for light blue and light gray.
"Dark blue" - pictured as ink blue, actually made gray blue.
"Light gray" - pictured as titanium gray, actually made light gray.
There are four five options available to those who purchased light blue or light gray:
1. Stay with the case and color available right now. This is the fastest and easiest method, but you will not get the color that you were expecting to.
2. Reanodize the case to the appropriate color. This is strongly not recommended due to potential issues/blemishes with the case after reanodizing, but will be faster than option 3.
3. Have a new case made in the ink blue or titanium gray. This is the most preferred method to get you exactly what you want, but will take another two one month. If you are willing to wait, I highly recommend this.
4. Refund.
5. Swap your gray blue (the previous "dark blue" option) case for a light gray case. This is dependent on having one buyer of each color decide to choose option 3, 4, or 5, and will have the least impact on the  fulfillment date, after option 1.
Options 3 and 4 will mean a forfeiture of your current order, and I will have to sell it (along with some other stuff) to gain the funds and proceed. I do not expect that to take too long, however.
I'd like to hear the thoughts of the participants on this. I will be sending out PMs w/ a link to this so we can discuss the available options and if there's anything else to be done, then I'll make a Google Form for the light gray/light blue participants to fill out.
I'll be on the plane in another 36 hours, and will be MIA for about 48 after that, but I'll be back, and I'll definitely get this sorted out properly.
That's all due to the factory differences, unfortunately. It's not like cyan, more of a darker sky blue. I honestly think it's beautiful, but no color is everyone's cup of tea.
« Last Edit: Sun, 10 July 2016, 14:14:15 by LunarisDream »
Offline breitling
Re: [GB] ZZ96 v2 r2 (ATTENTION light blue/light gray buyers)
« Reply #370 on: Sun, 10 July 2016, 02:08:59 »
Whats the problem with my deep blue one? is it the sort of light bluish one thats next to the cyan?
Edit: just looked up at the other posts and see the link.. i am okay with the blue that it came out. still looks pretty good.
« Last Edit: Sun, 10 July 2016, 02:13:01 by breitling »
« Reply #371 on: Sun, 10 July 2016, 02:18:24 »
Thank you. I'm very sorry about this.
Offline airs
« Reply #372 on: Sun, 10 July 2016, 03:07:01 »
Hey LD, I'm fine with the light gray result.
Octagon v2, LZ CLS
« Reply #373 on: Sun, 10 July 2016, 03:31:12 »
I know my explanation sucks and is confusing so here's a pic:
Offline gadzkun
« Reply #374 on: Sun, 10 July 2016, 04:04:58 »
Im okay with my light gray zz96 engraved. Just sent it to me asap xD.  youre teasing me too much with that sexy board :3
« Reply #375 on: Sun, 10 July 2016, 05:14:30 »
Noted, thank you!
Gotcha gotcha. I'll have it out as soon as the PCBs come in tomorrow.
Offline Gengarfan
Re: [GB] ZZ96 v2 r2 (ATTENTION dark blue/light gray buyers)
« Reply #376 on: Sun, 10 July 2016, 08:16:30 »
I think my order was light gray so if it is then I am fine with the new color and would just like to get the board when other US buyers do
Offline Butter
« Reply #377 on: Sun, 10 July 2016, 08:30:40 »
I am OK with the new grey blue. If someone doesn't want their light gray I'll take it.
Offline witbliz
« Reply #378 on: Sun, 10 July 2016, 08:39:52 »
I'm okay with whatever colour :) just no engravings hahaha clean and simple is how I like mine
Offline Gengarfan
« Reply #379 on: Sun, 10 July 2016, 08:57:24 »
edit: don't mind me
« Last Edit: Sun, 10 July 2016, 08:59:51 by Gengarfan »
« Reply #380 on: Sun, 10 July 2016, 21:02:54 »
Still sorting out orders. Also remembered I ordered a carbon fiber plate for testing. If someone wants it added to their order (on top of the existing plate - sorry, can't swap it out), it's $30. Please PM me if you'd like this to be added. Unlike the aluminum plates, this does not support ISO.
Edit: Sold
« Last Edit: Sun, 10 July 2016, 21:25:15 by LunarisDream »
« Reply #381 on: Sun, 10 July 2016, 21:23:29 »
Sent you a PM. I'll take it.
Re: [GB] ZZ96 v2 r2 (all responses sorted, prepping for shipment)
« Reply #382 on: Mon, 11 July 2016, 12:00:37 »
Bump w/ update.
Offline roostrc0gburn
  • its just plastic
« Reply #383 on: Mon, 11 July 2016, 13:14:53 »
I really appreciate how you run your group buys. lots of clear communication so no one is left guessing.
thanks again for all your hard work, LD! you are a great asset to the community
« Reply #384 on: Mon, 11 July 2016, 21:41:27 »
It's not on the layout chart, but looking at the CF plate picture and the PCB picture it looks like this board supports split left shift?
Offline Butter
« Reply #385 on: Mon, 11 July 2016, 23:14:03 »
Any change for pink or gold extra?
« Reply #386 on: Wed, 13 July 2016, 03:41:52 »
Just got home. Back in the US. PCBs arrived in China. Gonna take a couple days to get int'l orders sorted. I didn't have a lot of time due to the colors fiasco and had to sort the changes in the orders and then frantically pack my luggage (read: kb stuff). The orders in China will be sorted and taken care of in a few days, but not as soon as I'd like.
The U.S. orders have not yet shipped. There are still PCBs being tested and some logistical kinks that need to be ironed out (regarding some things being sent to the wrong people within China that need to be shipped back). Gonna update as I work through things.
What do you mean by change?
Thanks man, that means a lot.
Yep, it does.
Offline Butter
« Reply #387 on: Wed, 13 July 2016, 09:16:01 »
Sorry I meant to say any chance for pink or gold extra.
« Reply #388 on: Wed, 13 July 2016, 10:02:56 »
There aren't, unfortunately. You can place an order for the second batch with whatever color you want, though. :P
Offline Butter
« Reply #389 on: Wed, 13 July 2016, 10:43:51 »
I might have to do that if I have the fund :) Any idea when that will be?
« Reply #390 on: Wed, 13 July 2016, 11:59:28 »
Right now until I sort out the international orders. I'm worried about miscounting (especially now that I'm not in China), so I'll be having the int'l orders shipped first, then place the order for the next batch.
Offline WNovizar
« Reply #391 on: Wed, 13 July 2016, 15:01:10 »
 :cool: hahaha glad I avoided the messy situation by ordering sky blue instead of dark blue. Now ship dem zz96 asap !!!!
I like mechanical keyboards
  • its just plastic
« Reply #392 on: Wed, 13 July 2016, 15:21:27 »
unless you ordered one without a pcb, sounds like there are still some kinks to work out... :(
Offline rondg
« Reply #393 on: Wed, 13 July 2016, 18:16:37 »
I'm so in for the 2nd batch! I really need (need really means want) that cyan case :))
Offline Mike89914
« Reply #394 on: Wed, 13 July 2016, 21:42:21 »
Hey Lunaris, I'm in for the second batch if there is one!!  (this is seung_yeob from reddit)
Offline buzzking00
« Reply #395 on: Thu, 14 July 2016, 18:20:32 »
What do you still have for sale?
Are these pre-assembled or kits?
« Reply #396 on: Fri, 15 July 2016, 00:28:01 »
Alright dude, here's the info I need from you:
Not taking more orders. Want to keep the # at a comfortable level to move things along.
Your full name:
Your shipping address + phone #:
Your payment option (Dwolla/GW preferred for US, Stripe/Paypal for international):
Your payment option's email:
Case color:
Plate color:
The cost is $315 shipped worldwide.
I will need the above info to be PM'd to me. If I do not reply within 24 hours, then something's wrong.
Not taking a whole lot of extra orders because it will add unnecessary delay to the folks who are waiting from the first batch.
It's all in the chart in the OP. The boards are sold as kits. Assembly is possible if you talk to me.
« Last Edit: Fri, 15 July 2016, 08:19:40 by LunarisDream »
Offline kenshinjeff
« Reply #397 on: Fri, 15 July 2016, 01:19:00 »
Offline Pieminister
« Reply #398 on: Wed, 20 July 2016, 11:48:04 »
I hope everything is still on track for shipping soon  :thumb: can't wait
Offline airs
« Reply #399 on: Thu, 21 July 2016, 11:37:37 »
I have an order with screw mount stabs - can I just change to PCB mount since it sounds like screw mount will be delayed for a while?
Octagon v2, LZ CLS
