Author Topic: undo, cut, copy, paste, keycaps  (Read 8660 times)
Offline hotrattz
« on: Tue, 22 March 2016, 12:34:59 »
Hi guys
I found these on pimpmykeyboard
http://pimpmykeyboard.com/sa-nuclear-keycap-set/
the "edit set" which i'm getting but, has anyone seen these in other colors preferabliy in red? Also has anyone seen a "save" key again, preferably in RED like ESC
thanks!
Offline Dernubenfrieken
Re: undo, cut, copy, paste, keycaps
« Reply #1 on: Tue, 22 March 2016, 13:17:27 »
Round 5/5a caps from 7bit off deskthority. Definitely has some of those as options.
Offline DrWizard
    • Doctor Wizard's Giant Musical Holiday Light Show
« Reply #2 on: Sat, 24 February 2018, 14:37:18 »
I've been hunting for a set of these for ages!  The Pimp-My-Keyboard Keyshop no longer has them.  I have a Corsair K95 with 18 macro keys and I'd like to find a set for cut, copy, paste, undo, print, save, open, bold, italic, underline, close, zoom in-out, flag, indent, send, style, font, color, borders, view, exit...  you get the idea.  The first 6 of those at least.  Guess I'm gonna end up getting a set of relegendable keys unless someone knows where I can find the cut-copy-paste ones
Offline ErgoMacros
« Reply #3 on: Sat, 24 February 2018, 20:42:26 »
Wasd will also print anything you want on their keycaps.
Look for "Custom" here: http://www.wasdkeyboards.com/index.php/products/keycap-set.html
One example: https://farm3.staticflickr.com/2933/32877235953_2607169cb8_b.jpg
You may have to buy a "full set" and use what you need.
$45 for a 61 key set.
Today's quote: '...“but then the customer successfully broke that.”
Offline captsis
  • Formerly matt2dlg
« Reply #4 on: Sat, 24 February 2018, 21:11:33 »
These would be amazing for a macro board!
Offline ErgoMacros
« Reply #5 on: Sat, 03 March 2018, 18:21:25 »
OK, just discovered another relegendable.. https://resolver.tools/product/kubic-keycaps-set-of-12/
12x12mm legends (flat) on a 17x17mm key cap. $9.50 for 12.
