Author Topic: I want to make my own NUMPAD.  (Read 4411 times)
Offline jchan94
  • Keyclack Inc
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« on: Thu, 24 March 2016, 01:20:11 »
Looking for a DIY solution for an external numpad and I'm wondering where to go to instead of Winkeyless. Not saying their option isn't GREAT (which it isss....), but I want options.
Let me know! Thanks GH!
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline Moistgun
  • Slippery When Wet
Re: I want to make my own NUMPAD.
« Reply #1 on: Thu, 24 March 2016, 12:05:47 »
Get a plate that could hold whatever switches you want.
Handwire them into a matrix.
Wire the matrix to a teensy.
Offline merlin64
    • MechMerlin
« Reply #2 on: Thu, 24 March 2016, 12:10:11 »
MassDrop currently has a kit for a numpad
https://www.massdrop.com/buy/revo-design-custom-cnc-aluminum-keypad?mode=guest_open
I hope I put the guest mode flag correctly
Offline Moistgun
  • Slippery When Wet
« Reply #3 on: Thu, 24 March 2016, 12:37:19 »
https://www.reddit.com/r/MechanicalKeyboards/comments/3zsf4k/photos_handwired_macro_pad_with_round_5_caps/
Heres a link to someones diy build with handwiring.
Merlin64's suggestion would be waaaaay cleaner though ^^^
Offline hoosieree
« Reply #4 on: Fri, 25 March 2016, 20:21:27 »
A Teensy has enough IO to do switch-per-pin for a standard numpad; no matrix or diodes required.
Offline Moistgun
  • Slippery When Wet
« Reply #5 on: Fri, 25 March 2016, 20:45:46 »
I've heard about this but never heard any other description of how to do it and program that.   Idk anything about programming with a teensy.   Could you explain a bit more detail or link to an explanation?
« Reply #6 on: Sat, 26 March 2016, 04:52:01 »
The no diode route means more wires - you connect one pin on each switch together and to a Teensy pin, and another wire from a teensy pin to each switch's other pin.
Firmware wise you should just be able to call it one row with lots of columns, there was a problem with EasyAVR where it didn't like having less than two rows but that was before the rewrite so might work now and if not you just configure a fake row with nothing connected.
Offline jip
« Reply #7 on: Tue, 29 March 2016, 04:13:44 »
If you chose to create it from scratch and want to do it with diodes, this webpage provides a good explanation on key matrices.
http://pcbheaven.com/wikipages/How_Key_Matrices_Works/
