Author Topic: G80-3000HSMGB/05 USB adapter?  (Read 3257 times)
Offline lost eden
« on: Thu, 10 December 2009, 20:30:49 »
I've got 2x Cherry G80-3000HSMGB/05, one of which I use at home on my desktop which has PS/2 ports. I'd like to keep the other one in the lab at university to use with my laptop, however my laptop doesn't have a PS/2 port. Are there any adapters that will allow me to connect the G80 to a USB port successfully? I presume that the board isn't dual-mode, otherwise it would probably have a USB plug on the end of the cable instead of a PS/2, so it will probably need an active adapter?
Also, my laptop is a Mac, which in my experience has rather dreadful keyboard support. The internal keyboard is a non-standard layout so I ended up putting stickers on some of the keys & using a custom keymap to make a standard layout & when I plug in a modern UK USB keyboard (Microsoft Digital Media 1.0A atm) some of the keys still aren't mapped properly - so does anybody have any experience using a standard UK-layout keyboard on OS X, in particular with a PS/2-->USB adapter?
Offline ricercar
  • mostly abides
« Reply #1 on: Thu, 10 December 2009, 22:54:43 »
Search this forum for blue box EDIT: blue cube. That's the ultimate PS/2 to Macintosh adapter, and only $7 too. I have three of em, and they work on every keyboard I've thrown at them.
« Last Edit: Fri, 11 December 2009, 16:31:36 by ricercar »
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #2 on: Fri, 11 December 2009, 02:55:21 »
That would have to be "Blue Cube", of course. We also have a whole Wiki entry dedicated to these adapters. If you don't feel comfortable ordering a Blue Cube from China, try hunting down the Belkin.
Offline xyzzy
« Reply #3 on: Fri, 11 December 2009, 03:58:41 »
In Europe, it can be ordered from Cablestar in the UK.
Shop link: http://cablestar.co.uk/products/usb2actvps2-usb-a-male-to-ps2-female-ps2-active-keyboard-adapter.html
Ebay link: http://search.ebay.com/390121070619
I bought a couple from them, quick shipping and zero problems.
« Last Edit: Fri, 11 December 2009, 04:01:58 by xyzzy »
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline ch_123
« Reply #4 on: Fri, 11 December 2009, 04:15:26 »
That ebay guy had them for cheap. I'm buying two of them to see what the fuss is about. I figure I owe to Ripster after he got a NIB Model F =P
Offline lost eden
« Reply #5 on: Fri, 11 December 2009, 11:15:51 »
Thanks for the input guys, I ordered one of those Blue Cubes from cablestar & it shipped the same day, so hopefully I'll be seeing it sometime early next week.
Now to see if I can get the department to buy me another Kensington Expert, because I can't afford a second one myself & don't want to carry my home one to & from the lab every day!
Offline lost eden
« Reply #6 on: Sat, 12 December 2009, 09:16:16 »
That was fast, it's arried already! Works flawlessley except the backslash key to the right of the left shift key (this is a UK layout) isn't mapped correctly, so I'll probably have to make another custom keyboard map when I have time & can remember how to do it.
Offline ch_123
« Reply #7 on: Sat, 12 December 2009, 09:18:17 »
Alot of those adapters are designed for US keyboards and therefore don't support European ones. The Belkin adapters don't have that issue.
« Last Edit: Sat, 12 December 2009, 09:20:41 by ch_123 »
Offline keyb_gr
  • Cherrified user
« Reply #8 on: Sat, 12 December 2009, 17:53:09 »
How'd you obtain that scancode? It should be 00_56, that's what SharpKeys sez. In the rollover test, it should register as "<226>".
(BTW: Any other apps for scancode sniffing? SharpKeys has this nasty habit of always re-establishing its program group if that has been moved elsewhere. I don't like it when applications try to be smarter than me.)
EDIT: 00 56 seems to be the code set 1 scancode, which is typically what you see in software on a PC. Code set 2 uses 61. In any case HID Usage ID 64 should be produced, and one would hope that this translates the same on a Mac.
« Last Edit: Sat, 12 December 2009, 18:08:07 by keyb_gr »
Offline Rajagra
« Reply #9 on: Sun, 13 December 2009, 03:13:33 »
Works fine for me. (Though the Colemak layout converts it to an extra hyphen for me.)
My dongle is blue, but it functions as intended.
