Author Topic: [QUESTION] 87U 55g enter key a bit.. loose / light?  (Read 1305 times)
Offline iLLucionist
  • Topre is Love.
« on: Fri, 25 March 2016, 15:05:10 »
I have been typing on my 87UB 55g for 3 months on a daily basis now, it's my main driver.
But today I've noticed that my enter key is REALLY light (feels like 25-30g) compared to all the other keys. It also feels lighter than the shift key below it and the backspace above it.
When I gently tap it (without pressing it, just touching it slightly), it sounds like there is rice paper under it or a slight rattle.
Anybody know what's up? Is it something to worry about or is my OCD playing up again?
Offline Vittra
  • Airflow Optimizer
Re: [QUESTION] 87U 55g enter key a bit.. loose / light?
« Reply #1 on: Fri, 25 March 2016, 15:26:20 »
+/- 15G variance on any specific rubber dome in the sheet.
Filco MJ Linear R LE TKL
