Author Topic: SOLVED: Some keys keep repeating it self, what is the problem ?  (Read 2395 times)
Offline b0f0
Hi,
1. What is the correct debounce time for greetech brown switches ? (for cherry mx is 5ms)
2. If a sign keeps repeating it self if I press it only once, is this a switch problem or a software problem or something else?
The problem:
I am editing C file for my ergodox firmware. Almost everything works but two keys are giving me problems.
If I press a key it repeats it self. And then it looks like this key never gives the command to stop. So if you press any other key
on the keyboard, that key doesnt work because the faulty key is still pressed. But not physicly it looks like the key doesnt recieve the command to stop outputting the charcter.
Physicly the key returns in normal position after releasing it, so this looks okey.
Now I am a bit lost, need your help.
The keyboard is ergodox.
« Last Edit: Sun, 27 March 2016, 09:49:23 by b0f0 »
Offline toidbb
Re: Some keys keep repeating it self, what is the problem ?
« Reply #1 on: Sat, 26 March 2016, 18:58:45 »
If it keeps on repeating over and over, does it stop if you press the switch again?
You may have a short from the solder of the switch or diode, to the case, or inside the switch that is causing the key to appear depressed after it has come back.
Offline b0f0
« Reply #2 on: Sat, 26 March 2016, 19:04:48 »
it doesnt stop repeating. Just keeps repeating. Even if I press the key again.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Sat, 26 March 2016, 19:18:14 »
Well you can rule out hardware if you want to test the Ergodox with pre-configured firmware.
Offline b0f0
« Reply #4 on: Sat, 26 March 2016, 19:25:14 »
It could be software or the soldering. I opened the Ergodox and the soldering looks good.
I m writting an email to the developer, maybe I forgot to write something in the C file.
Offline b0f0
« Reply #5 on: Sun, 27 March 2016, 09:49:03 »
Solved.
https://github.com/benblazak/ergodox-firmware
use partial-rewrite code not the master branch code, its much easier to programme the additional keys that way.
So it was not a hardware error. I am so happy !  ;D
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #6 on: Sun, 27 March 2016, 10:30:31 »
Solved.
Congrats! :)
