Author Topic: Hot swappable keyboard  (Read 2603 times)
Offline climbalima
  • likes building stuff
« on: Sat, 26 March 2016, 21:44:57 »
I have an idea to build a 60% keyboard with a detachable numpad, function row, and macro pad. I plan to use usb breakout boards to connect all the matrices together. The main issue I have in this conceptual phase is how I will secure the sections together.
Offline FlukeNukem
Re: Hot swappable keyboard
« Reply #1 on: Sat, 26 March 2016, 21:49:16 »
Neodymium magnets to snap them together would hold well without having to fabricate a latching mechanism
CM Storm QFR Cherry MX Green
Dell AT101
IBM Model F 5291 "Bigfoot"
Offline climbalima
« Reply #2 on: Sat, 26 March 2016, 22:00:03 »
That does sewm like a possible solution. Thanks!
Offline Kompanion
« Reply #3 on: Sun, 27 March 2016, 20:49:07 »
Be careful with strength. There's a strong possibility to break smaller components if go full strength and let them "slam" together.
________________________________________________
