Author Topic: V60 caps lock issue  (Read 1278 times)
Offline jcoffin1981
V60 caps lock issue
« on: Sat, 26 March 2016, 21:49:08 »
About once a day the caps lock becomes stuck in the on  p osition.  However,  I have the dipswitch set to that the caps lock is really an Fn key.  To fix this problem I have to turn  the dipswitch off.  Then press the caps lock and turn it off, then flip  the dipswitch again.  Does this  happen to anyone else or is there a  way to prevent this?  When this  happpens the Caps lock light is on as if it is really engaged, which it is.
Offline jcoffin1981
Re: V60 caps lock issue
« Reply #1 on: Sun, 27 March 2016, 06:48:19 »
My  keys have no markings on them so it makes it more difficult, but I discovered that if you press FN + Tab it overides the dip switch  function of turning the caps lock into a Fn key.  Maybe this will help someone else.  If you want to permanently disable the caps lock it will have to be done perhaps through windows.
