Author Topic: Silenced HHKB is awesome...but I lost my spacebar spring!!!  (Read 10696 times)
Offline tominabox1
« on: Sun, 27 March 2016, 08:20:39 »
I lost the secondary spring that goes under the space bar  :eek: ...I know some of you have removed yours...if you may be willing to part with it, I'd be happy to have it!
I went to the orthodontist and they hooked me up with "medium" weight 1/4" elastics.  They fit perfectly and, man this is a new keyboard!
Offline iLLucionist
  • Topre is Love.
Re: Silenced HHKB is awesome...but I lost my spacebar spring!!!
« Reply #1 on: Sun, 27 March 2016, 13:13:36 »
No worries. I actually REMOVED those springs under all my Topre spacebars.
Offline FLFisherman
  • I'd rather be fishing.
« Reply #2 on: Sun, 27 March 2016, 16:52:08 »
How's it feel? I would try it myself, but I always worry about creating the spacebar whenever I remove it.
Offline tominabox1
« Reply #3 on: Sun, 27 March 2016, 18:29:14 »
Feels exactly the same but the weight is a little lighter I suppose as the spring compensated for the larger mass of the keycap.  Easiest way to take the space bar off is to take off the keys on either side then pry with your fingers evenly.
Offline iLLucionist
  • Topre is Love.
Re: Silenced HHKB is awesome...but I lost my spacebar spring!!!rba
« Reply #4 on: Sun, 27 March 2016, 18:49:05 »
For me, it feels smoother and a bit quieter. But I usually also reverse my spacebar.
« Reply #5 on: Sun, 27 March 2016, 18:56:12 »
Many people seem to lose their HHKB space bar extra spring.
Needs a warning label :))
Or someone to supply replacements ...
Offline iLLucionist
  • Topre is Love.
« Reply #6 on: Sun, 27 March 2016, 18:57:57 »
I wonder why it is even put on there.. That spring feels so weak that I would think it is useless.
Offline FLFisherman
« Reply #7 on: Sun, 27 March 2016, 19:21:51 »
Ahh, maybe I'll give it a go. I'll probably lose the spring as well when I attempt this.
« Reply #8 on: Sun, 27 March 2016, 20:14:48 »
Subtle effect to offset the heavier space bar.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #9 on: Sun, 27 March 2016, 22:32:58 »
Same, I REMOVE all my spacebar springs from all my Topre boards.
It feels nicer and more consistent to me.
Having the spring under spacebar is like using MX Red board with MX Black spacebar, or MX Blue board with MX Green spacebar.
Offline tominabox1
« Reply #10 on: Sun, 27 March 2016, 22:34:02 »
Did any of you actually save the spring?
Offline iLLucionist
  • Topre is Love.
« Reply #11 on: Mon, 28 March 2016, 10:26:28 »
I save it for well.. I don't know actually. But I have a special box for springs and that really small stuff you're gonna loose otherwise.
« Reply #12 on: Mon, 28 March 2016, 12:57:57 »
Or not to be stupid OnO
Offline FLFisherman
« Reply #13 on: Mon, 28 March 2016, 12:58:45 »
I hope you lose your spring when you flip your spacebar back.
Offline iLLucionist
  • Topre is Love.
« Reply #14 on: Mon, 28 March 2016, 12:59:25 »
That's mean..
Offline FLFisherman
« Reply #15 on: Mon, 28 March 2016, 13:02:24 »
That's mean..
I hope you sneeze and no one says "bless you."
Offline Kompanion
« Reply #16 on: Tue, 29 March 2016, 19:35:36 »
Where did I see that a retainer band for braces worked pretty well in place of a spring? Doesn't sound too terrible.
I personally just took a spring from a friend who prefers going springless  :))
________________________________________________
Offline nmur
  • ಠ_ಠ
« Reply #17 on: Tue, 29 March 2016, 19:43:51 »
I also take my spacebar spring out deliberately from my topre boards. otherwise it's too stiff and I miss spaces :(
so I have a couple laying around, but unless you're in Australia the shipping would be killer
Offline tominabox1
« Reply #18 on: Tue, 29 March 2016, 20:24:53 »
so sad.... alas, no
