Author Topic: Black on Black  (Read 3931 times)
Offline merutz
  • @merutz
Black on Black
« on: Sun, 27 March 2016, 15:54:59 »
Tried searching but these are not the best keywords to search for in the forum.
Can anyone point me to an MX set similar to the HHKB black on black colorway? As in, as black as possible, unlike that Originative wannabe.
QFR R-i/DSA Dolch   |   MX Master
     + yellow Esc
Offline KnivesM
Re: Black on Black
« Reply #1 on: Sun, 27 March 2016, 16:04:55 »
https://geekhack.org/index.php?topic=71995.0
http://imsto.cn/index.php?route=product/product&path=62&product_id=108
IMSTO has some in stock but the shipping is expensive, that GB I think is one of the ones Ivan has disappeared on but there was a sucessful round 1 that my set is from.
« Last Edit: Sun, 27 March 2016, 16:07:07 by KnivesM »
Others
Offline merutz
  • @merutz
Re: Black on Black
« Reply #2 on: Sun, 27 March 2016, 16:44:27 »
Thanks mate! I'll be sure to look into them!
     + yellow Esc
Offline TalkingTree
    • My projects
Re: Black on Black
« Reply #3 on: Sun, 27 March 2016, 17:42:47 »
Shadovved claimed there will be extras in his, now closed, GB.
Offline eohmiller
Re: Black on Black
« Reply #4 on: Fri, 13 May 2016, 16:21:00 »
Just curious, why not blanks?
Offline merutz
  • @merutz
Re: Black on Black
« Reply #5 on: Sat, 14 May 2016, 04:45:01 »
They're too minimalistic. I'm getting the HHKB in the end.
     + yellow Esc
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Black on Black
« Reply #6 on: Sat, 14 May 2016, 11:27:58 »
Geekkeys offers a set of dark grey with black legends but I'm willing to bet that they're not the dark keycaps that you're looking for. Probably a little bit lighter than hhkb/RF dark grey caps.
« Last Edit: Sat, 14 May 2016, 12:21:40 by csmertx »
Offline Malenky
Re: Black on Black
« Reply #7 on: Sun, 15 May 2016, 07:14:09 »
If black on black were as black as possible, you wouldn't see the legends. The whole point is that the keys are not quite black.
