Author Topic: A custom keyboard layout with common keycap sets in mind.  (Read 2674 times)
Offline validifyed
« on: Tue, 29 March 2016, 14:00:40 »
So I posted a thread recently asking people about looking for custom keycaps - particularly when you are looking to find caps for a custom layout.
The conclusion was pretty simple and one that I expected, but disappointing. You have to be ready to spend more than your fair share of money, and/or be prepared to have a set that does not perfectly suit your preference. Kinda a bummer when you are building a custom layout; you want it to be exactly what you want, and have already spend enough money building the damn thing. That said, if you like the idea of a Unicorn puke layout, all power to you, lol.
So how about this:
A custom layout built from the keycap set for a TKL keyboard.
Green keys represent a standard 60% layout, white keys have been copied over from the full TLK layout at the top, all of them are either 1u (Of which there are plenty in excess), or they are the same size as one of the removed  green keys.
The only exception is the red key, as there is only a single 1.75u on a standard layout. Not a problem if you dont mind having a 0.5 blank on your layout (Spare 1.25s are available). It is a shame that this will still limit your choices slightly, but less so, as you can either opt for the blank space or replace capslock or another key with something different.
Alternatively, you can replace >, /, Shift each with 1.25u's (There are enough), this leaves no blanks but might be a little less neat depending on how you see things.
Personally I think its a nice compromise, offering extra keys for macro or simple re-binding in a more compact 60/65% layout while still allowing you to get keycaps easily. Let me know what you think!
Re: A custom keyboard layout with common keycap sets in mind.
« Reply #1 on: Tue, 29 March 2016, 14:10:56 »
That's called a 65% layout. It's not anything new, I'm afraid.
From [IC] LZ-SQ Housing & Finger L3 PCB
Although I must say that I do think the layouts for the LZ-SQ are more well thought out and more useful.
Offline validifyed
« Reply #2 on: Tue, 29 March 2016, 14:18:59 »
I was aware that arrowkeys added to standard 60% was a thing (Although thanks for pointing out that it has an official name as 65%) - I looked through the link though and could not find anything about trying to cater for pre-existing keycap sets, so I dont know if that was a thing that the keyboard shown is aiming for? The reason why I did this for 65% was out of personal preference for that layout, however the main focus of the post was the keyset advantage it offers.
« Reply #3 on: Tue, 29 March 2016, 14:49:25 »
The bottom rows with only 1u, 1.25u, 1.5u and 6.25u/7u keys are standard. It's extremely easy to get all of those sizes of keys for most keysets. The only ones that are hard to get are the 6u keys, and it's also hard to get keys with correct legends for an _entirely_ 1u bottom row (e.g 1/1/1/7/1/1/1/1/1/1)
Also, the one aspect you've shown which the SQ doesn't support is the 1.25/1/1/1/2.25/2.75/1.25/1.25/1.25/1/1/1 bottom row. However, honestly, that bottom row is harder to find keys for (with correct legends) than most of the other bottom row arrangements which the SQ offers.
