Author Topic: I upgraded my CODE with Raindrop DSA's!  (Read 4831 times)
Offline ifearghal
« on: Wed, 30 March 2016, 17:38:17 »
I'm really excited about the keycaps as I didn't run across techkeys.us until I came here. Here is the link to the imgur album of the keyboard. I'm really liking the look even though the keycaps are not backlit compatible. I used the number pad keys for the number/symbol row and I'm still debating that choice.
I just wanted it to share it with y'all!
http://imgur.com/a/wpuwM
« Last Edit: Wed, 30 March 2016, 17:41:20 by ifearghal »
CODE TKL: MX Browns/Raindrop DSA in Blue and White|
Corsair K95 Full Size: MX Red: OEM
Re: I upgraded my CODE with Raindrop DSA's!
« Reply #1 on: Thu, 31 March 2016, 05:07:05 »
I've always liked the blue and white look :)
Offline the big aristotle
« Reply #2 on: Sun, 03 April 2016, 17:28:50 »
Those look pretty sweet! How do you like DSA? I had one set but my typing accuracy went wayyyyy down.
Offline trillobite
« Reply #3 on: Sun, 03 April 2016, 17:36:21 »
Oh wow, that is unexpected, I would have assumed the opposite would have happened, as the keys seem fit the shape of your fingers better. I am personally a big fan of SA, and DSA key's... but I sadly don't own a set yet... :(
« Reply #4 on: Sun, 03 April 2016, 17:36:55 »
I haven't seen Raindrop on a black board before, it looks just as good as on a white one :)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Sun, 03 April 2016, 18:35:10 »
Mhm, this looks really good
Offline ifearghal
« Reply #6 on: Tue, 05 April 2016, 20:51:48 »
Thank you. I'm really happy with it.
Offline ifearghal
« Reply #7 on: Tue, 05 April 2016, 20:51:59 »
Offline ifearghal
« Reply #8 on: Tue, 05 April 2016, 20:52:47 »
Admittedly I was a little nervous about how it would come out. I'm happy to see it looks this good. Types like a dream too.
Offline ifearghal
« Reply #9 on: Tue, 05 April 2016, 20:56:07 »
I really enjoy DSA. I used a set in a friend's poker 2 and couldn't go back to the standard keys. In fact, I had the standard keys on the CODE for less than a week. It was surprisingly uncomfortable.
Offline ifearghal
« Reply #10 on: Tue, 05 April 2016, 20:56:56 »
What are the differences between DSA and SA?
« Reply #11 on: Tue, 05 April 2016, 21:45:46 »
SA is a much higher profile, generally thicker keycaps.
http://keycapsdirect.com/key-caps.php
