Author Topic: Maltron Ergonomic 2-hand  (Read 2922 times)
Offline ricercar
  • mostly abides
« on: Sat, 12 December 2009, 11:20:50 »
http://cgi.ebay.com/Maltron-ergonomic-two-handed-keyboard-retails-600_W0QQitemZ150395868542QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item23044ad57e
No trackball. Starts at $100 USD.
FWIW my Maltron is curiously not manufactured as well as my Kinesis, the materials and machining appear inferior. Overall I'm disappointed in Maltron, considering the retail price is twice the Kinesis retail. Review pending.
« Last Edit: Sat, 12 December 2009, 11:31:38 by ricercar »
Offline Rajagra
« Reply #1 on: Sun, 13 December 2009, 00:22:34 »
Quote from: ricercar;141712
Maybe because they are hand-made?
They are hand made from sheet materials which are formed and punched to make the shell or body of the keyboard. Individual Cherry MX key switch are individually fitted by hand. The switch contacts are wired up into a scanning XY matrix by hand. In fact everything is done on an individual basis by hand.
« Last Edit: Sun, 13 December 2009, 00:27:26 by Rajagra »
Offline bsvP585hUO2Y6
Re: Maltron Ergonomic 2-hand
« Reply #2 on: Sun, 13 December 2009, 06:16:52 »
Whoa, they actually mean it when they write "wired by hand", not just
soldered to a pcb by hand:
,----[ http://www.maltron.com/maltron-kbd-flat-assembly.html ]
| The key-modules are then wired up in an XY matrix. Discrete wiring
| rather than a dedicated PCB is used as this allows complete
| customisation of the keyboard's switch arrangement.
There's also picture in this article where you can see the wiring.  It
looks like they use polyurethane enamelled wire to make this process
economically feasible.
« Last Edit: Sun, 13 December 2009, 06:40:14 by bsvP585hUO2Y6 »
