Author Topic: Which switches?  (Read 3947 times)
Offline xondat
  • i'm not a star
Which switches?
« on: Thu, 31 March 2016, 18:56:45 »
I've tried the following switches, all stock, all in plates.
  • MX Reds - they are way too light and ****
  • MX Browns - too light but a decent bump
  • MX Clears - too heavy and bump a bit too big
  • Gat Blacks - SO SMOOTH but too light
I'd prefer to not bottom out but that's kind of unavoidable. 3mm travel would be perfect but I'm scared that I wouldn't hit actuation all the time.
If someone could advise me on which springs to get then that'd be great.  :-* :-*
Offline bocahgundul
  • a seal
Re: Which switches?
« Reply #1 on: Thu, 31 March 2016, 18:59:41 »
U could get a spring to swap em into your liking
I think get a 67g springs?
Offline solemnP
Re: Which switches?
« Reply #2 on: Thu, 31 March 2016, 19:01:23 »
Sounds like you would like gateron browns with a heavier spring, not sure about what spring though.
Offline xondat
  • i'm not a star
Re: Which switches?
« Reply #3 on: Thu, 31 March 2016, 19:07:29 »
Aren't 67g springs bottom out not actuation?
Offline bocahgundul
  • a seal
Re: Which switches?
« Reply #4 on: Fri, 01 April 2016, 05:51:23 »
yes they are bottom out not actuation
Offline xondat
  • i'm not a star
Re: Which switches?
« Reply #5 on: Fri, 01 April 2016, 08:17:04 »
All this gibberish with springs confuse me too much. Might just go for 67g and hope for the best.
Offline FLFisherman
  • I'd rather be fishing.
Re: Which switches?
« Reply #6 on: Fri, 01 April 2016, 08:22:14 »
Rubber dome.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Which switches?
« Reply #7 on: Fri, 01 April 2016, 09:21:18 »
Definitely Cherry Mx Grey, definitely grey
Offline xondat
  • i'm not a star
Re: Which switches?
« Reply #8 on: Fri, 01 April 2016, 09:46:58 »
80g actuation will destroy me, clears are like 5g too much
Offline pwade3
Re: Which switches?
« Reply #9 on: Fri, 01 April 2016, 10:42:14 »
Aren't zealios lighter than clears but heavier than browns?
Offline xondat
  • i'm not a star
Re: Which switches?
« Reply #10 on: Fri, 01 April 2016, 12:25:50 »
I think so but aren't they measured on bottom out?
Offline Waateva
Re: Which switches?
« Reply #11 on: Fri, 01 April 2016, 12:27:16 »
I think Zeal has said that the 78g Zealious feel just a tad lighter than stock Clears.
Re: Which switches?
« Reply #12 on: Sat, 02 April 2016, 01:45:32 »
Zealios?
3mm travel - you'll still have 2mm travel to actuation, but O-rings can reduce further travel to 1mm, making a total travel distance of 3mm.
Offline xondat
  • i'm not a star
Re: Which switches?
« Reply #13 on: Sat, 02 April 2016, 04:52:16 »
So 67 or 78 zealio ._. I think 78?
O rings make me cry.
Offline bocahgundul
  • a seal
Re: Which switches?
« Reply #14 on: Sat, 02 April 2016, 05:08:06 »
Just get an HHKB and ur good to go
Re: Which switches?
« Reply #15 on: Sat, 02 April 2016, 05:24:33 »
The above post has the seal of approval.
