Author Topic: Considering A Mech Keyboard, don't own one yet, advice on caps please.  (Read 3862 times)
Offline bjfmonkey
Ok, so i'm on a tight budget and will buy this: http://www.amazon.co.uk/dp/B00CITN98G/?tag=pcp0f-21. I've seen in many places that it has low profile keycaps, if this is true can they be replaced with just keycaps in general? like will they fit? This is probably a REALLY stuid question but i've never had a mechanical keyboard before.
Offline zslane
Re: Considering A Mech Keyboard, don't own one yet, advice on caps please.
« Reply #1 on: Fri, 01 April 2016, 21:25:18 »
They can be replaced by any keycaps with MX stems, which are the most common type. You will have a lot of keycap sets to choose from.
Offline xiaodian317
« Reply #2 on: Fri, 01 April 2016, 22:51:49 »
The CapsLock and spacebar are not fit.
Offline bjfmonkey
« Reply #3 on: Sat, 02 April 2016, 01:28:59 »
What do you mean?
« Reply #4 on: Sat, 02 April 2016, 01:51:43 »
Welcome to Geekhack!
My guess would be (to the above interpretation) that the space bar has non-standard stem spacing, and probably the keyboard has off-centre-stem caps lock (most modern ANSI winkey layouts have centre-stem caps lock).
Offline bjfmonkey
« Reply #5 on: Sat, 02 April 2016, 07:37:21 »
First of all, thank you. Second of all even though the picutre on that is ANSI its actually an ISO (uk) one.
Offline ykno
  • Frustration, Face Meet Keyboard.
« Reply #6 on: Sat, 02 April 2016, 11:27:16 »
i own this keyboard (uk layout) and its fine with the low profile caps its great and not to claky so perfect to use in a office for work which is where i use mine i would leave the stock low proifle caps on it as it will look stupid with taller caps on
id say its a good board but not for gaming (can be used for gamin with out issue) but its more of a productive keyboard for work!
you can get coolermaster cm storm quickfire keybaord on amazon for about teh same price btw ( more of a gaming keyboard if that what your after but ye for a office go with the cherry its a great board)
« Last Edit: Sat, 02 April 2016, 11:33:40 by ykno »
     Filco TK       Tomoko TK
« Reply #7 on: Sat, 02 April 2016, 19:51:36 »
ISO/ANSI - most have centre stem caps lock (except Korean customs).
Offline ykno
« Reply #8 on: Mon, 04 April 2016, 05:24:09 »
i just compared the keys on my mx board 3.0 to my filco the keycaps spacing is all the same my filco spacebar fits on my mx board 3.0
     Filco TK       Tomoko TK
