Author Topic: space bar sound is very pingy  (Read 5739 times)
Offline ykno
  • Frustration, Face Meet Keyboard.
« on: Mon, 04 April 2016, 05:14:13 »
space bar sound is very pingy compared to rest the keys on my filco majestouch tenkeyless i put some o rings on it but still very loud compare to rest anythign else i can do?
     Filco TK       Tomoko TK
Re: space bar sound is very pingy
« Reply #1 on: Mon, 04 April 2016, 06:03:10 »
There's a lot more plastic in the space bar - pretty much every keyboard I've used the space bar sounds different.
If it's really noticable, can you make a video or sound recording of it?
« Reply #2 on: Mon, 04 April 2016, 13:13:32 »
Yeah, the space bar is the one that sounds most different, expect on my linear boards, for some reason. It used to annoy the frick out of me, but I've gotten used to it.
Offline pr0ximity
« Reply #3 on: Mon, 04 April 2016, 13:22:34 »
Lubricate the wire stabilizer where it touches the inserts in the keycap as well as the brackets on the plate. Makes a pretty huge difference in the amount of rattle, especially when paired with lubing the ends of the spring inside the switch.
Offline mobbo
  • u fk
« Reply #4 on: Mon, 04 April 2016, 13:29:32 »
^ pretty much this.
My Filco spacebar was rattling as well, greased the stabilizers a little bit and now it is a joy to press (and listen to).
Quote from: Binge
