Author Topic: LCD Repair  (Read 7079 times)
  • Live long and prosper
LCD Repair
« on: Sun, 13 December 2009, 12:32:46 »
So my dad had a Dell E172FPB LCD monitor, and about 2 months ago it gave up the ghost.  It would turn on and display something for about 2 seconds, then it would black out.  So I had looked it up on google, and found that these monitors were prone to failure.  They had defective transistors that, after a few years, would burn out and cause the backlight not to turn on.  I found that the simple fix was to just take out the bad transistors and replace them.  So the moral of the story is, if you have a bad LCD monitor with those symptoms, chances are it can easily be repaired to good as new condition.  Anyone else have this same problem with any of their LCD's?
tp thread is tp thread
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
LCD Repair
« Reply #1 on: Sun, 13 December 2009, 14:31:40 »
Reading up on this, it seems that while replacing these transistors will make things work again in the short term, they may eventually fail again. The root cause seems to be bad solder joints together with a design problem.
BTW, aren't those the kind of Dells with these awful vertically arranged menus?
LCD Repair
« Reply #2 on: Sun, 13 December 2009, 14:41:42 »
idk what the menus look like.  Even if the transistors aren't the cause of the problem, it only costs $4 for a repair kit, and the transistors can last about 3 years, so $4 every 3 years plus a little work isn't that bad.  Plus, it will give me something to do every 3 years.
LCD Repair
« Reply #3 on: Sun, 13 December 2009, 14:59:43 »
I have to work to get my good computer equipment.  This being my first and only LCD monitor, I knew I wasn't going to be getting the best thing in the world.  Either way, I am still happy I was able to fix this one.
Offline InSanCen
LCD Repair
« Reply #4 on: Sun, 13 December 2009, 17:02:58 »
I have a samsung 4:3 19" LCD here that I got for nothing. Previous owner moved it about a lot, and consequently unplugged the VGA cable a lot. Re-soldered it, and hey presto. One monitor for browsing (19" Fujitsu-Siemens 16:10) and the aforementioned Samsung for code and other misc junk. Compiz on multi-monitor setups is just great... I just need to get that 7" touchscreen modded in on the S-Video connection now... mmmm....
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
LCD Repair
« Reply #5 on: Sun, 13 December 2009, 18:04:49 »
I just got back home and I have plugged in my repaired LVD monitor and it is working beautifully.  I am not use to using an LCD monitor, it is so alien to me...
Offline Rajagra
LCD Repair
« Reply #6 on: Sun, 13 December 2009, 19:06:36 »
Normally if an LCD goes dark it's a failed inverter board and you just swap it out. But if you can pin it down to the exact component (or two) so much the better.
Be careful of high voltages when you poke around these things. They are safer than CRTs, but can still be nasty.
LCD Repair
« Reply #7 on: Sun, 13 December 2009, 19:09:23 »
When I looked up how to fix it, the instructions said that the problem was 4 transistors on the inverter board that had gone bad.  It was a simple fix.  I didn't have any trouble with it, me and my dad unsoldered the old transistors and soldered in the new ones and now I have one decent LCD monitor.
Offline Hak Foo
  • Make America Clicky Again!
LCD Repair
« Reply #8 on: Sun, 13 December 2009, 20:21:42 »
Quote from: Computer-Lab in Basement;142105
I had a Viewsonic VX910 which I spent $350 on, replaced with a $65 secondhand 21" CRT.
After about 3 years, it went to 'power, no picture'.
A bunch of bulging capacitors on the PCB.  Replacing 'em did nothing.
I will stick to super-off-brand names now
Overton130, Box Pale Blues.
Offline timw4mail
    • https://timshomepage.net
LCD Repair
« Reply #9 on: Mon, 14 December 2009, 07:11:15 »
That reminds me, on of these days I should fix the DVI port that went poof on my Sceptre X22 monitor...
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
LCD Repair
« Reply #10 on: Mon, 14 December 2009, 14:48:51 »
Doesn't it have a VGA port too? If it does, then that shouldn't be much a problem as it is.
LCD Repair
« Reply #11 on: Mon, 14 December 2009, 15:44:10 »
Only one of my computers has a DVI port, and the monitor for it is VGA, so I just use the VGA port instead.  What is the major difference, besides the pin configuration?
Offline keyb_gr
  • Cherrified user
LCD Repair
« Reply #12 on: Mon, 14 December 2009, 16:33:37 »
Quote from: Computer-Lab in Basement;142304
DVI can also carry an analog VGA signal (DVI-I), but the interesting thing is the digital transmission (TMDS). No syncing mess or varying black and white levels, always a stable picture. Analog outputs are better if you have really long cable runs, but for normal use DVI has much superior handling.
(Even though there are some monitors like my Samsung which take much longer for a mode switch than with analog input and even show occasional drop-outs at times (not sure whether it's my sample or the model in general). Whoever decided that the backlight was to be the first thing to be turned off upon signal loss deserves to be fired. Eizos are much more smartly designed in this regard, but it's a pity they couldn't do anything but full-screen interpolation for a long time.)
Offline timw4mail
LCD Repair
« Reply #13 on: Mon, 14 December 2009, 16:37:01 »
Except the picture is sharper with the DVI connection.
Offline keyb_gr
  • Cherrified user
LCD Repair
« Reply #14 on: Mon, 14 December 2009, 19:52:25 »
Quote from: timw4mail;142322
Dang, I knew I'd forgotten something. Yeah, there are plenty of cards with lousy analog outs out there... beware of any low-profile ones which have the VGA out attached by a ribbon cable. A number of generic GF2MX cards was pretty blurry, too.
My work PC had a 1600x1200 Eizo L885 20" screen on a Matrox G550 (analog out, as DVI is limited to 1280x1024 on these cards) - no complaints about sharpness, but I could never get timing 100% perfect. It was good enough, but a pixel-level checkerboard pattern (think Win2k shutdown dialog and such) always showed a bit of flickering.
Offline bsvP585hUO2Y6
Re: LCD Repair
« Reply #15 on: Tue, 15 December 2009, 02:18:28 »
keyb gr wrote on 5949 September 1993:
> Quote:
>     Originally Posted by timw4mail View Post
A lot of cards also sport overzealous low-pass filters behind the vga
socket for EMI reasons.  Shorting these increases the chances for a
perfect analog picture.  IIRC there was some article about it in the c't
magazine a decade ago.
I can confirm: Eizo + Matrox = perfect image on LCD via analog.
Luckily, I'm no gamer and thus can live with my Matrox Millenium II with
4MB RAM just fine :-).  I used to have an AGP G400 but needed to
downgrade due to lack of a suitable slot when I upgraded the
Mainboard...
I can get perfect timing, but the temperature drift sometimes thwarts my
attempts.  +/-3°C and the phase is slightly off, needing readjustment.
Offline Rajagra
LCD Repair
« Reply #16 on: Tue, 15 December 2009, 02:20:01 »
My Dell 2405FPW screens do an amazing job with analog 1920x1200 signals. I switch between DVI and VGA to use my 2 PCs, and I really can't tell the difference. The colours probably suffer more than sharpness - converting from digital to analogue in the PC, and then back to digital within the TFT creates two unnecessary conversions that have to have some effect.
I can't use an analogue KVM though - the ghosting is horrible at these resolutions.
