Author Topic: NMB/Hi-Tek ANSI Space Invaders  (Read 2080 times)
Offline engicoder
« on: Wed, 06 April 2016, 11:49:27 »
Finally found myself an ANSI Space Invaders board. It has linear white switches with a linear green for the space bar.
Re: NMB/Hi-Tek ANSI Space Invaders
« Reply #1 on: Wed, 06 April 2016, 11:55:31 »
Looking good! I really need to explore space invader switches
Offline engicoder
« Reply #2 on: Wed, 06 April 2016, 11:56:30 »
I'll bring you a board in June
Offline jacobolus
« Reply #3 on: Wed, 06 April 2016, 12:07:22 »
fohat is going to be so jealous.
I recommend swapping the spring between the spacebar and the Pause key or something. The standard spacebar weight on these is ridiculous.
Offline engicoder
« Reply #4 on: Wed, 06 April 2016, 16:08:27 »
That's ok, most of my work is xcriptio continua so I don't need the spacebar anyway  :p
Truthfully, you are right, the spacebars on most Space Invaders boards are way to heavy, but I have found that after a short time I don't really notice...until my arthritis starts complaining. Of course upon, but returning to a more typical keyboard I end up hammering the spacebar.
