Author Topic: How do you know what "percent" a compact keyboard is?  (Read 8143 times)
Offline hoosieree
« on: Fri, 08 April 2016, 12:32:56 »
I'm guessing the formula is just:
[number of keys rounded to nearest multiple of 5][percent-sign].  For example if you have a 52 key device, it'd be "50%".
But I never saw this formally defined, so I'm asking.
Offline piemancoder
Re: How do you know what "percent" a compact keyboard is?
« Reply #1 on: Fri, 08 April 2016, 13:04:40 »
Sometimes it works like this, but not all the time. I think the way it works is based off of the three biggest form factors, 100%, 80%, and 60%. After that, if you make a different layout, it's based off of one of those. For example, the FC660C has a few more keys than a 60%, and is called a 66%
Yoda grammar best has
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Fri, 08 April 2016, 13:24:44 »
Off the top of my head:
100% -> fullsize
87% -> tenkeyless
75% -> compact / laptop
60% -> no numpad, nav or F keys
40% -> JD's layout
1% -> keychain
« Reply #3 on: Fri, 08 April 2016, 13:35:57 »
That's basically correct. Common sizes are referred to as:
100% = 104/105/108-key layout
80% = 86/87/88/91-key layout (TKL)
75% = 82/84-key layout
65% = 60% plus one column. Usually with dedicated cursor arrows.
60% = main section of a standard keyboard, without tenkey, nav cluster, or F-row. 5x15.
40% = 4x12 or 4x13 minimalist.
Offline 0100010
  • Not Sure
« Reply #4 on: Fri, 08 April 2016, 13:56:43 »
100% -> fullsize
87% -> tenkeyless
40% -> JD's layout
1% -> keychain
Ha - I like that 1%....
Now - what about bigger boards, like an Ortek MCK-142 Pro?
Offline chyros
  • a.k.a. Thomas
« Reply #5 on: Fri, 08 April 2016, 14:05:48 »
100% -> fullsize
87% -> tenkeyless
40% -> JD's layout
1% -> keychain
144%, one of my favourite layouts ;D .
Offline iLLucionist
  • Topre is Love.
« Reply #6 on: Fri, 08 April 2016, 14:57:10 »
So now I finally now what a 40% is... thanks!
Offline hoosieree
« Reply #7 on: Fri, 08 April 2016, 20:06:27 »
Cool, thanks for confirming.  I guess it's not an exact science.
Offline iLLucionist
  • Topre is Love.
« Reply #8 on: Sat, 09 April 2016, 07:18:02 »
I believe it mostly started when we started with Tenkeyless keyboards or the idea that you could have a keyboard without a numpad. That was an 80%, but that's still made up because literally 87 / 104 is 83.65% (rounded at two decimal places). And it went from there I believe.
