Author Topic: Looking for TKL with cherry MX Clear  (Read 4395 times)
Offline TheInverseKey
  • You can run but you cannot hide!
« on: Sun, 10 April 2016, 19:27:58 »
Hi,
I am looking for a TKL with cherry MX clear switches.  In addition, the keyboard has to be very sturdy due to the factor that it will be traveling a lot and I personally dislike a keyboard that has flex to it.
Thanks
Offline KatzenKinder
Re: Looking for TKL with cherry MX Clear
« Reply #1 on: Sun, 10 April 2016, 19:29:05 »
https://elitekeyboards.com/products.php?sub=keyed_up_labs,tenkeyless&pid=es87u_cc_bbb_al
Probably the easiest one to get, I think? I've heard rather good things about KUL, though I've never personally used one.
« Reply #2 on: Sun, 10 April 2016, 19:44:04 »
Does that use cherry or costar stabilizers?
Offline klennkellon
  • I like bottoming out
« Reply #3 on: Sun, 10 April 2016, 19:47:29 »
KBParadise V80's from www.mechanicalkeyboards.com
Stock caps are kind of lame, but a pretty solid board all around.
« Reply #4 on: Mon, 11 April 2016, 05:59:36 »
Cherry.
Also consider a CODE (Costar stabilisers): http://www.wasdkeyboards.com/index.php/products/code-keyboard/code-87-key-mechanical-keyboard.html
Edit: Massdrop has a CODE drop at the moment: https://www.massdrop.com/buy/code-keyboard-tenkeyless?mode=guest_open
« Last Edit: Mon, 11 April 2016, 15:16:06 by rowdy »
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #5 on: Tue, 12 April 2016, 00:12:35 »
KUL
Ganss
CODE
Mmm... machined aluminum
Offline carmenohio
« Reply #6 on: Thu, 14 April 2016, 16:22:36 »
