Author Topic: KUL ES-87  (Read 1622 times)
Offline TheInverseKey
  • You can run but you cannot hide!
KUL ES-87
« on: Sun, 10 April 2016, 20:53:20 »
Hi,
After a recent post I was introduced to this keyboard and was pondering a question. I know from the reviews that I have found that the keycaps are crap that come with it.  Therefore, was looking at replacing them right off of the bat.  Is the spacebar on this keyboard an odd size what I mean by this is that I have a Corsair K70 and the spacebar is an odd size.
Thanks Inverse
Offline Waateva
Re: KUL ES-87
« Reply #1 on: Sun, 10 April 2016, 20:56:03 »
The ES-87 has a standard bottom row unlike the K70, so yes, you could replace the keycaps on the KUL easily.
Re: KUL ES-87
« Reply #2 on: Sun, 10 April 2016, 21:08:23 »
Thanks
