Author Topic: Starting keycap crafting  (Read 176568 times)
Offline geniekid
Re: Starting keycap crafting
« Reply #100 on: Tue, 10 May 2016, 20:14:06 »
I just really want gumdrops now :))
Offline alexjd99
  • oozing through the cells of one's own construction
« Reply #101 on: Tue, 10 May 2016, 20:24:22 »
Guys!
Still not perfect, but at least its not bubbles that are causing the issues now!
Oh dude! This purple is soooooo nice. Casts are looking hella clean now. Can't wait to see more
Offline JT_Sea
  • Um hi
« Reply #102 on: Wed, 11 May 2016, 10:03:25 »
Thanks man! I may be able to cast a new one tonight. Got the new box of oomoo in last night, made the first 1/2 of the mold before bed and poured the 2nd part this morning before work. She's sitting in the pressure pot right now. Hopefully I didn't eff something up..
Really interesting to see the progress you're making (you move so fast!). Seeing a lot of improvement with the pressure pot! Those purp goombas are looking quite tasty d:
Thanks! I feel like I"m moving so slow, I'm glad to see someone things I'm moving quickly.
great improvement!!!
Thank you! I'm excited to start getting some caps out to my 'backers'. I sent them DM on reddit this morning with progress shots. Everyone seems pretty excited about the purps.
I love that you're active in posting updates. It looks like you're progressing nicely and it's nice to see you're excited about it.
So I might have had a small nightmare about casting last night.. Guess that tells you something about whats on my mind currently.
« Last Edit: Wed, 18 January 2017, 19:54:27 by HoffmanMyster »
Offline JT_Sea
  • Um hi
« Reply #103 on: Thu, 12 May 2016, 07:40:01 »
Still have one minor issue, but the second cap I cast last night didn't have it so I might have that sorted out. I did some heavy sanding on the master before making this mold, and now that I have a few to test I'll see how well they fit on my board + macropad today. Might need to do some more sanding..
Offline Mattc777
  • Lost Keys
« Reply #104 on: Thu, 12 May 2016, 07:45:06 »
Ice Goomba! Man the progress is real! Nice work sir, this looks great!
Offline JT_Sea
  • Um hi
« Reply #105 on: Thu, 12 May 2016, 10:07:09 »
Test fitting on a display board.
The OG goomba had some fitting issues with the large lip -
So I spent some time with a few pieces of sandpaper and the master over the weekend.
Still a little snug, but I think it works.
Interestingly enough from this photo it looks like the OG gooms has more clearance. It doesn't.
Now to cut out the mx stem, cast a few caps sans stems and make a few bases out of mx + topre + alps. More updates to follow tomorrow :D
Offline Moistgun
  • Slippery When Wet
« Reply #106 on: Thu, 12 May 2016, 10:10:24 »
Listerine Goomba?
Offline Moistgun
  • Slippery When Wet
« Reply #107 on: Thu, 12 May 2016, 10:16:12 »
Just a heads up
I found topre and alps to need the same technique for making the stems mold work correctly.
And alps is super easy to get a decent cast of the stem, while topre is seemingly more difficult.
all that said, I dont have a pressure pot like you do...
 :thumb:
Offline JT_Sea
  • Um hi
« Reply #108 on: Thu, 12 May 2016, 10:20:20 »
Just a heads up
 :thumb:
I'm sure you noticed the drastic improvement in the stem on the mold earlier, I'm hoping that a topre stem will work out equally well when curing under pressure.
I've gotta say though, the pressure pot is almost like magic. I'm so glad I sold my SA sets & artisans& placeholders to get some better equipment. I'm really curious to know how a vac pot will help the process, and a high pressure valve in the pressure pot.
Listerine Goomba?
Love the name! I think I'll use it when I do a public sale.
Offline Moistgun
  • Slippery When Wet
« Reply #109 on: Thu, 12 May 2016, 10:34:10 »
Just a heads up
 :thumb:
Listerine Goomba?
Oh yea, the difference is night and day, and goes without saying.
Im really happy for you to be able to get this sweet set up.
I think you got the big change out of the way, and the vacuum will just be a nice compliment to the pressure.
IMO working on projects and creating stuff is much more satisfying than collecting cap sets and hoarding **** lol.
Offline JT_Sea
  • Um hi
« Reply #110 on: Thu, 12 May 2016, 10:39:55 »
From a creative standpoint its way more satisfying, but sometimes hoarding is great :D
Offline Moistgun
  • Slippery When Wet
« Reply #111 on: Thu, 12 May 2016, 10:46:27 »
collect what you enjoy and hoard what you create. lol
Offline JT_Sea
  • Um hi
« Reply #112 on: Thu, 12 May 2016, 23:57:53 »
Well, I thought I had the goomba refined enough...
Doesn't look bad from here.
Whaaa wha
So, solved the problem!
J/k, here's what it looks like on the macro pad
And after more work tonight
Its still going to end up being a snug cap, but I think we're in a spot now
« Reply #113 on: Fri, 13 May 2016, 00:04:31 »
 :thumb:
Offline dannrawr
« Reply #114 on: Fri, 13 May 2016, 03:00:00 »
from the front looks like goomba is eyeing on me
WTF any Bruce, Cosmonauts
Offline JT_Sea
  • Um hi
« Reply #115 on: Fri, 13 May 2016, 08:21:50 »
They're a creeper for sure. Always there, just watching..
Offline geniekid
« Reply #116 on: Fri, 13 May 2016, 08:30:31 »
You know they're just waiting for an opportunity to jump you...or is it the other way around?!
Offline biocalves
« Reply #117 on: Fri, 13 May 2016, 08:30:42 »
Looking better!
Sent from my SAMSUNG-SM-G920A using Tapatalk
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #118 on: Fri, 13 May 2016, 08:39:57 »
then you press the key and the Goomba is smooshed :cool:
Offline dannrawr
« Reply #119 on: Fri, 13 May 2016, 09:06:57 »
Offline Moistgun
  • Slippery When Wet
« Reply #120 on: Fri, 13 May 2016, 10:07:51 »
The key spacing is always an issue when jumping into a new design.  keep tweaking and make your babies perfect!
Offline JT_Sea
  • Um hi
« Reply #121 on: Fri, 13 May 2016, 14:06:31 »
Offline Moistgun
  • Slippery When Wet
« Reply #122 on: Fri, 13 May 2016, 14:17:05 »
Nice lil goomba
this one fit better?
Offline JT_Sea
  • Um hi
« Reply #123 on: Fri, 13 May 2016, 14:20:55 »
Nice lil goomba
Nope, just ran out of resin when I was pouring the pseudo caps. The one with the crappy white teeth is the only cap amongst the bunch.
Offline Moistgun
  • Slippery When Wet
« Reply #124 on: Fri, 13 May 2016, 14:32:36 »
Nice lil goomba
Cool.
Have you made any blanks at all?
Offline JT_Sea
  • Um hi
« Reply #125 on: Fri, 13 May 2016, 14:33:56 »
Nice lil goomba
Cool.
Nope, not yet. I should get around to it one of these days. I figure I'm doing good just getting the casting process down better, then I can expand after that.
Are blanks worth while to make?
Offline Moistgun
  • Slippery When Wet
« Reply #126 on: Fri, 13 May 2016, 14:46:40 »
Nice lil goomba
Cool.
Almost all my caps are for personal use, so it depends on what you like
Sent from my fingers at a local payphone
Offline JT_Sea
  • Um hi
« Reply #127 on: Sat, 14 May 2016, 23:28:55 »
Updates!
And if you look at the set on the left, you can see they are touching then if you look at the right hand set you can see they aren't touching. I would guess that the goombas will fit on any board now. I'll give it a shot on the magicforce 68 on Monday.
Offline JT_Sea
  • Um hi
« Reply #128 on: Mon, 16 May 2016, 15:30:43 »
Double shots
I'm calling this set gloombas
Tried mixing too little for the black, it didn't cure so thats all a goopy mess.
Next time, I'll not make that same mistake.
Dark purp
And don't forget your pills
Offline Moistgun
  • Slippery When Wet
« Reply #129 on: Mon, 16 May 2016, 15:38:51 »
Nice job!
I do not like doing double or triple shots, process wise, but damn do they make a cap look wayyy better.
Offline JT_Sea
  • Um hi
« Reply #130 on: Mon, 16 May 2016, 15:46:40 »
Nice job!
Agreed - I now understand why those caps fetch higher values.
« Reply #131 on: Mon, 16 May 2016, 15:49:04 »
Double shots
Dark purp
Those are too many to keep for yourself.  ;)
Offline JT_Sea
  • Um hi
« Reply #132 on: Mon, 16 May 2016, 15:52:15 »
Double shots
Dark purp
Gotta get the caps out to my backers first! But stay tuned to r/mk r/mm :D
Offline Moistgun
  • Slippery When Wet
« Reply #133 on: Mon, 16 May 2016, 16:05:56 »
Double shots
Dark purp
How ever will you decide who gets single color and who gets the dubs?
Idk how many people you sold to already, or did you just promise place holders?
Offline JT_Sea
  • Um hi
« Reply #134 on: Mon, 16 May 2016, 16:11:54 »
I'm thinking Random.org will be very valuable in my future. I also will add a caveat on my sale posts that anyone who wants to trade for caps I'm looking to acquire will get top priority! At least thats what I'm thinking now, I haven't worked out the specifics yet.
I actually already have a private list of folks waiting for the goombas, I think I'll do a private sale first before I do a public one. Need to make sure everyone is okay with the quality first and foremost.
I have sent a few out as gifts to friends who have helped me out along the way, their reviews should provide valuable insight into the caps and if they'll stand up to a public release.
Offline Moistgun
  • Slippery When Wet
« Reply #135 on: Mon, 16 May 2016, 16:30:13 »
that seems fair enough.
hopefully you can land a cap that you have been looking for in the process
Offline JT_Sea
  • Um hi
« Reply #136 on: Mon, 16 May 2016, 16:36:21 »
Gotta study the masters!
Offline biocalves
« Reply #137 on: Wed, 18 May 2016, 13:16:56 »
Not seeing an update here daily makes me worried. Are you ok?  :))
Offline Moistgun
  • Slippery When Wet
« Reply #138 on: Wed, 18 May 2016, 13:25:15 »
calves is right, you are the most dedicated I have seen in a while.
Offline JT_Sea
  • Um hi
« Reply #139 on: Wed, 18 May 2016, 14:39:51 »
Sorry guys, just busy with fam and working on getting keys setup for my backers. I actually do have some updates to post, I'll try to get those up today.
Just a hint :
4x mold tonight
New sculpt
Wifey sculpted a cap
Triple shot success!
Offline Mattc777
  • Lost Keys
« Reply #140 on: Wed, 18 May 2016, 14:41:12 »
Just a hint :
4x mold tonight
New sculpt
Super excited to see new designs/sculpts! Killin' it sir!
Offline JT_Sea
  • Um hi
« Reply #141 on: Wed, 18 May 2016, 14:43:49 »
Thank you thank you! I'm super excited to get my backers caps in the mail, and I'll have enough after that to start reaching out to my private R1 list. Shouldn't be more than a week or so and I'll be posting public R1 on /mechmarket. Gotta keep that small though, don't want to die.
Offline biocalves
« Reply #142 on: Wed, 18 May 2016, 14:44:34 »
Just a hint :
4x mold tonight
New sculpt
Just relieved you're not lying in a ditch somewhere.  :p
Offline JT_Sea
  • Um hi
« Reply #143 on: Wed, 18 May 2016, 14:47:59 »
Just a hint :
4x mold tonight
New sculpt
:D with a missing box of goombas!
btw your friend jumped in for a blind box gooms - you'll have that in your package.
Offline biocalves
« Reply #144 on: Wed, 18 May 2016, 14:48:58 »
Just a hint :
4x mold tonight
New sculpt
Oh did he? Yeah ship it to me, I'll make sure he gets it......
Offline JT_Sea
  • Um hi
« Reply #145 on: Wed, 18 May 2016, 14:55:08 »
Just a hint :
4x mold tonight
New sculpt
:D You two can sort that out!
Offline JT_Sea
  • Um hi
« Reply #146 on: Thu, 19 May 2016, 00:08:24 »
Minor update
I've got a few gooms ready to head out, but I think I'll wait till they are all ready to go out for my backers.
4X is curing as I type this - also notice the far left stem..
First time triple shots have come out close to correct. The black could be darker, but I'm 100% happy with these guys.
It was cold the other night in the basement, so when I pulled this one out it was still mushy, so I mushed it a little more. Sadly the  stem didn't make it, otherwise this baby'd be on my keyboard.
New cap sculpting
And as promised, my wife did a first pass on a sculpt. I present the golden snitch
Offline biocalves
« Reply #147 on: Thu, 19 May 2016, 00:13:20 »
Minor update
New cap sculpting
Holy Crap!!!! Both of those new sculpts look amazing. Absolutely love the detail work on the chain on your sculpture as well as the wing shape on your wife's! Great job man.
Offline Mattc777
  • Lost Keys
« Reply #148 on: Thu, 19 May 2016, 00:18:22 »
Oh man that chain chomp.  :thumb:
Also those triple shots turned out very good!  :cool:
Gotta say - Every time I press the one I have on my board I hear this in my head :
« Last Edit: Thu, 19 May 2016, 00:25:07 by Mattc777 »
Offline dannrawr
« Reply #149 on: Thu, 19 May 2016, 01:13:40 »
Minor update
New cap sculpting
would love to have that blue/teal haha. nice new sculpt
