Author Topic: Leopold vs Varmilo PBT keycaps  (Read 5504 times)
Offline riko
« on: Thu, 14 April 2016, 13:21:24 »
Can it be that Leopold PBT keycaps are the same as Varmilo keycaps?
Offline user 18
Re: Leopold vs Varmilo PBT keycaps
« Reply #1 on: Thu, 14 April 2016, 13:50:23 »
I'd say it's possible, given the relationship between varmilo and leopold.
Avatar by ashdenej
Offline ThoughtArtist
« Reply #2 on: Fri, 22 April 2016, 00:42:07 »
Leopold caps have sharp bottom corners since they weren't designed for a floating keyboard.
I thought my Varmilo looked cool with the Leopold caps but the corners of the caps would scratch and poke against my hands and I hated it.
« Last Edit: Fri, 22 April 2016, 01:10:55 by ThoughtArtist »
