Author Topic: I'm cheap. This may not be the best forum for me.  (Read 3025 times)
Offline H-Man
« on: Thu, 14 April 2016, 21:21:17 »
I am just a college student suffering from RSI. Tried to use regular keyboards, rubber dome and mechanical caused me too much grief. After 10 years, I gave up and switched to a PS2 MS ergo that I got at the thrift store for $3. That bought me about a year. I switched to Dvorak (took me 6 weeks to adjust) and that bought me about 2 years. As reports got longer, I observed how I was mistyping things and realized that staggered columns were an issue for me. A bit of searching found me the kinesis and I found one on craigslist for cheap. The rest is history.
Keyboards:
Kinesis Advantage MPC USB/QD I got for $50 [Main]
Kinesis Classic I got for $50 [Backup]
IBM model M from 1984 that I got for free. [Family gaming box]
Microsoft Ergonomic I spent too much money on. [paper weight]
Offline beehatch
  • baehatch
Re: I'm cheap. This may not be the best forum for me.
« Reply #1 on: Thu, 14 April 2016, 21:40:28 »
Stay, just don't get into artisan keycaps.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Fri, 15 April 2016, 18:46:07 »
Welcome :D I had a ms ergonomic board years ago that I loved until it stopped registering some of the keys. If Kinesis boards weren't so hulk-like I would seriously consider them
Offline pr0ximity
« Reply #3 on: Fri, 15 April 2016, 19:12:56 »
Always wanted to try a Kinesis, they look awesome. Think I would need one with linears.
« Reply #4 on: Sun, 17 April 2016, 05:37:52 »
Welcome to Geekhack!
It's been a long journey for you, but glad you've finally found a solution to your RSI.  Or at least a way to work with it.
There is an ergonomics section, where you're welcome to share your experience.  Perhaps it will help someone else :)
Offline izilla
« Reply #5 on: Thu, 21 April 2016, 20:49:13 »
Welcome to the forum I do not have RSI but I do get swollen knuckles and tight joints in my hands every now and again (might be RSI I am just in denial). But there are newer solutions besides the kinesis I have used a couple of their early models but not for an extended period of time. I am getting a UHK from Crowd Supply later this year and an Ergodox too because I think the split keyboard is a cool idea. I will report back after some use with my results.
Offline cozmonort
    • Coz Caps
« Reply #6 on: Fri, 22 April 2016, 09:21:18 »
Welcome to GH, just need to exercise considerable restraint... Something I fail at.... *shakes fist at Bro's 420 sale*
« Reply #7 on: Sun, 24 April 2016, 02:46:27 »
The trick is to only get the keycaps you really want to see on your keyboard.
Just imagine having the keycap on the keyboard in front of you, or a small pile of cash sitting next to the keyboard.  Then ask yourself which you would prefer.
