Author Topic: Hi from Hanoi  (Read 2860 times)
Offline breaker9691
Hi from Hanoi
« on: Sat, 16 April 2016, 12:36:00 »
Hello, i have created account pretty long time but not spend much times and forum, hope that i can learn something
I'm using HHKB Pro2, HHKB Pro2 Type-s, HHKB and some "gaming keyboards" and learning to make something for my own.
Re: Hi from Hanoi
« Reply #1 on: Sun, 17 April 2016, 05:49:03 »
Welcome to Geekhack!
Only just over 18 months ago!
Also, welcome to the HHKB club ;)
Offline bazh
Re: Hi from Hanoi
« Reply #2 on: Sun, 17 April 2016, 05:53:26 »
ib4 demik comes and recruit this man to his church
HHKB Pro2 white
Newbie again
Offline breaker9691
Re: Hi from Hanoi
« Reply #3 on: Sun, 17 April 2016, 06:02:39 »
so we have HHKB Club ?, that nice, i always love HHKB and try to modified it many times, lube and make it more quiet, then after set it's all to normal and buy another hhkb type-s haha
Re: Hi from Hanoi
« Reply #4 on: Sun, 17 April 2016, 06:04:06 »
Many prefer the sound and feel of the standard HHKB!
Plus the Type S ones have been know to whistle sometimes.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hi from Hanoi
« Reply #5 on: Sun, 17 April 2016, 07:57:14 »
Welcome! demik is the official HHKB club leader ;)
Offline breaker9691
Re: Hi from Hanoi
« Reply #6 on: Sun, 17 April 2016, 09:35:13 »
yeah, i know that, some body just try to make it silence, and i know that the hhkb pro2 typing sound is loudly and is great, if you want to have a quiet version the just buy the type-s right, haha
@csmertx : i will find him asap hehe
Re: Hi from Hanoi
« Reply #7 on: Mon, 18 April 2016, 05:41:15 »
You can try putting a sheet of material under the HHKB to dampen the sound.  It makes a huge difference.
I use a folded sheet of drawer liner.  Some people use rubber mats, or thick large mouse pads.
You can even try a tea towel to see if it makes a difference.
Something rubber also helps to stop the HHKB from sliding across the desk.
