Author Topic: Would an ANSI keyboard work like an ISO keyboard  (Read 10933 times)
Offline enimole
« on: Sat, 16 April 2016, 13:20:36 »
Hey keyboardhumans
I live in switzerland and we use here the ISO layout with the letter öäü and its quite hard to find compatible keycaps for that. So Im not sure if I can ask that here but will a ANSI keyboard still work like an ISO keyboard if you keep the settings on your computer on german? Would it miss any keys?
Offline Olumin
  • "Guy walks into a doctor's office..."
Re: Would an ANSI keyboard work like an ISO keyboard
« Reply #1 on: Sat, 16 April 2016, 13:42:26 »
Unless you change the layout on your operating system, using a ANSI keyboard will not change anything. So yes, you can still use the ISO layout with an ANSI keyboard. I use a HHKB myself and switch back and forth between German ISO and ANSI, it works fine for me.
« Reply #2 on: Sat, 16 April 2016, 13:47:40 »
There are alternative keycaps available but primarily for MX-style switches. You might be able to find junked keyboards to salvage caps from.
- D Trump 2026-10-24
Offline soilheart
« Reply #3 on: Sat, 16 April 2016, 14:00:29 »
Yes. An ANSI keyboard can be used with an ISO keysetting, with some caveats.
I would assume that the key above the ANSI enter would map to the left of the ISO Enter, so you just need to learn to find the £$}-key in a different spot (above the ANSI Enter).
The <>\-key would be missing though, as ISO keyboard have an extra key compared to an ANSI keyboard, so you wouldn't be able to write <, > or \ without some custom keybinding/application.
EDIT: So to answer your question. Yes, one key would be missing, and one key would be moved.
(K70 -  Brown) --- Pok3r - Clear --- Ducky Shine4 - Clear --- WKL B.face X2 - 67g Zealios --- CP-SQ - 78g Zealios --- RS68 - 62g Zealios
(Sold/retired - To be built)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Sat, 16 April 2016, 15:08:58 »
I use UK ISO on all my keyboards, including ANSI and International ones. It works fine, except that the pipe key | sends # instead on non-ISO boards, so I have to use alt+124 for that.
Offline seville57
« Reply #5 on: Sun, 17 April 2016, 05:29:19 »
Hey keyboardhumans
I'm from Sweden and we also use the ISO (Nordic) layout  with the letters Ö, Ä and Å. It is a hell to find good lookin ISO/Nordic keycaps sets here in Sweden.
We have shop 1 that sellin ISO Nordic keycaps sets, the shop has some sets from WASD.
Some years ago I bought a ISO Nordic Cherry MX keycaps set from WASD (US), you can take a look here: http://www.wasdkeyboards.com/index.php/products/keycap-set/105-key-iso-cherry-mx-keycap-set.html
http://support.wasdkeyboards.com/customer/en/portal/articles/1374997-are-your-keycaps-compatible-with-backlit-keyboards-
So after some time I bought my first ANSI k-board, I'm runnin swedish Win 7 64 bits HP, usin the ISO Swedish keysettin.
My white ANSI Ducky One RGB YOTG and one of my ISO/Nordic Ducky Shine 3 k-boards.
« Last Edit: Sun, 17 April 2016, 09:16:26 by seville57 »
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Sun, 17 April 2016, 05:40:29 »
Is the G key not working on your keyboard by any chance? XD
