Author Topic: About carrying keyboard  (Read 4316 times)
Offline bchen112
« on: Mon, 18 April 2016, 21:04:28 »
I'm a student and I carry my hhkb daily to the school. I'm now using a soft sleeve and I usually just put the keyboard in the bag with other notebook and other stuff. My bag is heavy and there are a lot in there. I'm always afraid that since I'm only using a soft sleeve, the continuous pressure of the weight of the bag or the book will damage the topre switch, or make the key feels less satisfying. I already got a roof for the keyboard so that in the future I can put the hhkb in the sleeve with the roof so that the key won't got any pressure in the bag. However, I'm still afraid that by carrying the keyboard for a few days, I've already done some damage to the keyboard. Is that even possible?
« Last Edit: Mon, 18 April 2016, 21:09:48 by bchen112 »
Offline reaper
Re: About carrying keyboard
« Reply #1 on: Mon, 18 April 2016, 21:48:28 »
I use this when I have to throw my keyboard in the backpack, etc.  Got it from WaterField a few year back... not sure if they still make them.
Din Eli
« Reply #2 on: Mon, 18 April 2016, 22:08:05 »
Offline Jokrik
« Reply #3 on: Mon, 18 April 2016, 22:13:24 »
I feel ya, I often carry my hhkb back and forth from and to the office, with small bag
Currently I also live with soft case, and a hard case would take much space in your bag unless it's a perfect fit
What I do is I just make sure that nothing is against/preassurize the switch side, usually put it on top of everything in the bag
Offline E3E
« Reply #4 on: Mon, 18 April 2016, 22:27:58 »
https://elitekeyboards.com/products.php?sub=access,cases&pid=pdkb01sd
I always liked this for carrying the HHKB
I use this from my 60% Hammer Alps board. It's a great case. For my Orion v2, I use an aluminum case with foam I cut out for the Orion v2. I want to get a smaller aluminum case for my Lightpad (I already have one designed for the Lightpad and Octagon as a pair, but it doesn't fit the look of the current set up I have).
Offline mike52787
  • Alps Aficionado
« Reply #5 on: Fri, 22 April 2016, 20:22:48 »
Anyone know of a bag big enough to hold a f122?  :p :))
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #6 on: Fri, 22 April 2016, 21:11:02 »
A trash bag.
« Last Edit: Fri, 22 April 2016, 21:20:12 by Olumin »
Offline mike52787
  • Alps Aficionado
« Reply #7 on: Fri, 22 April 2016, 21:23:36 »
A trash bag.
Ouch.
Offline Olumin
« Reply #8 on: Fri, 22 April 2016, 21:25:29 »
Offline mike52787
  • Alps Aficionado
« Reply #9 on: Fri, 22 April 2016, 21:26:43 »
Offline ThoughtArtist
« Reply #10 on: Sat, 23 April 2016, 02:51:43 »
Just sew it into the bag itself.
135203-0
Offline ander
  • I type, therefore I am
« Reply #11 on: Sat, 23 April 2016, 04:49:40 »
bchen112: You have nothing to worry about. Even if there is some pressure on your keyboard, it won't hurt anything because the pressure is distributed between so many switches.
If you took a few springs out of a mattress and stood on them, you could damage them. But when you lie on a mattress full of springs, your weight is evenly distributed over all of them, and the springs hardly move.
Try this:
1. Disconnect your keyboard.
2. With your open hand, press down on the keys.
You'll see that you can hardly press it at all, because all those springs are sharing the weight.
I've carried MK's around in backpacks with all kinds of stuff, and have never had any problems. As long as you use a sleeve to prevent scratches, you'll be fine. Cheers, A.
« Reply #12 on: Tue, 26 April 2016, 07:10:23 »
Try this:
I'm curious what keyboards you are carrying around?
Obviously not a hhkb.
Offline frogthejam19
  • Good Vibrations
« Reply #13 on: Tue, 26 April 2016, 13:45:47 »
I use a cheap gun pouch I got off from Amazon for lik 8 bucks each. They fit 60% Keyboards like a glove
"All is Well"
Offline ander
« Reply #14 on: Tue, 26 April 2016, 15:57:24 »
That's pretty cool! Then people may also think you may be "packing heat" and not mess with you.  :?D
