Author Topic: I ordered Zealios; how can I install them?  (Read 5635 times)
Offline reduc3r
« on: Tue, 19 April 2016, 11:18:57 »
Just ordered 90 78g Zealios. (I like a firm switch.)
So, um, how can put them in a keyboard?
I looked around and discovered this Winkeyless B.87 option. It's a very handsome keyboard, but I don't really need backlighting.
I'm aware of Clueboard, but I prefer a TKL layout.
Maybe it would be easier to take apart a manufactured keyboard, remove the switches, and install the Zealios? If so, what would be a good keyboard for that?
Any thoughts or guidance would be greatly appreciated.
Offline phosphoric
Re: I ordered Zealios; how can I install them?
« Reply #1 on: Tue, 19 April 2016, 11:22:37 »
build the wkl without backlighting. desoldering is a pain in the ass
Let's get this straight. There is nothing cool about keyboards we're all lame as fk.
speak for yourself
Offline Keycap
« Reply #2 on: Tue, 19 April 2016, 11:27:01 »
I find that buying a super cheap mech is cheaper than buying the plate, PCB, casing, diodes, controller, etc. which makes absolutely no sense if you think about it.
« Reply #3 on: Tue, 19 April 2016, 11:32:46 »
It's all about what kind of specifics you want in a board that is kind of the point of this entire hobby.
Many people want custom boards to get all the features that come with them.
For soldering/desoldering cheap boards can easily be destroyed due to their poor quality.
Offline dante
« Reply #4 on: Tue, 19 April 2016, 11:41:06 »
Elite Keyboards has a few KUL ES87's on ebay in the $60-$80 range that should suite your needs.
The PCB is beef cake.
Offline pwade3
« Reply #5 on: Tue, 19 April 2016, 11:42:19 »
I mean, a manufacturer buying in bulk is probably getting those at a significant discount compared to a regular user.
Offline phosphoric
« Reply #6 on: Tue, 19 April 2016, 13:49:09 »
economies of scale
speak for yourself
Offline reduc3r
« Reply #7 on: Tue, 19 April 2016, 14:18:58 »
Hm. That sounds like it could work, maybe.
Offline ideus
  • Björkö.
« Reply #8 on: Tue, 19 April 2016, 14:25:45 »
De-soldering is not a trivial work, you can damage the paths of the PCB and the matrix; but, maybe you have extensive experience with it, so just forget the comment.
Offline iLLucionist
  • Topre is Love.
« Reply #9 on: Tue, 19 April 2016, 14:39:18 »
Good to know, I thought about desoldering a board myself. Better buy parts and assemble myself then.
Offline reduc3r
« Reply #10 on: Tue, 19 April 2016, 14:52:35 »
No fraid not. I've built PCs, that's about it. No soldering or desoldering was required.
Yeah, I'm gonna have to think about this. Maybe that Winkeyless is the way to go.
Offline pwade3
« Reply #11 on: Tue, 19 April 2016, 14:55:13 »
Make sure you get some soldering practice before diving into the board itself. Zealios are particularly sensitive to chattering due to the nature of their transparent plastic housing.
Offline iLLucionist
  • Topre is Love.
« Reply #12 on: Tue, 19 April 2016, 15:02:14 »
How does a transparent plastic housing increase chattering?
Offline Saiph
« Reply #13 on: Tue, 19 April 2016, 15:04:02 »
Something about the plastic having a lower melting point
Offline pwade3
« Reply #14 on: Tue, 19 April 2016, 15:05:34 »
Zeal himself mentioned that transparent plastics have a lower melting point.
Offline iLLucionist
  • Topre is Love.
« Reply #15 on: Tue, 19 April 2016, 15:20:51 »
Chattering is double registering of a key right? So if you press 'k' it will register as 'kk' or 'kkk'. How does a little bit melted key housings affect chatter? Or is this a really stupid question?
Offline pwade3
« Reply #16 on: Tue, 19 April 2016, 15:25:08 »
That's my understanding of chattering as well. But I think it's just enough melting/warping to change how the internals of the switch sit, I don't know either honestly, maybe someone else has a better explanation.
Offline iLLucionist
  • Topre is Love.
« Reply #17 on: Tue, 19 April 2016, 15:26:06 »
I can imagine that... perhaps it just affects the contacts / pins a bit as well.
Offline KatzenKinder
« Reply #18 on: Tue, 19 April 2016, 15:33:32 »
No, it absolutely makes sense. The economies of scale dictate the prices at which manufacturers will sell bulk products. A manufacturer like CM or KUL will more often than not be able to purchase all of the required parts in amounts far beyond what the smaller, niche-focused sellers like winkeyless or others would be able to. Therefore they receive much better prices per part than the smaller alternatives.
Offline ideus
  • Björkö.
« Reply #19 on: Tue, 19 April 2016, 16:55:31 »
Exactly for the same reason, if what you want is an stock keyboard just to change the switches that approach is correct; but, if what you want is to build a custom board with programmability and other non-stock features a cheap stock board is not the answer.
Offline reduc3r
« Reply #20 on: Thu, 21 April 2016, 20:50:47 »
Thanks for the advice, guys. I appreciate the assistance. I have the switches, and I'll keep it in mind.
After reading through the comments and assessing my available free time, I've rethought my philosophy, and I'm thinking maybe I'd better just content myself with what's available pre-built, at least for now. I didn't quite realize the scale of this endeavor.
But the switches are there if I ever decide to return to this.
« Last Edit: Thu, 21 April 2016, 21:36:01 by reduc3r »
Offline cozmonort
    • Coz Caps
« Reply #21 on: Fri, 22 April 2016, 09:51:31 »
Hey man, I recently got a b.87 and put zealios in it, I got winkeyless to solder all the small stuff and just soldered the switches.. It was surprisingly easy.. that said, as stated above, I'd steer well clear of any desoldering or fiddly soldering.
I'd say keep your zealios and find a board you like that's sold complete but without switches.. It's not hard to just solder in the switches... and it's well worth it.
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #22 on: Fri, 22 April 2016, 10:53:57 »
No much more sense than often buying a new printer is cheaper than buying the ink itself is....Such is the odd world we live in.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
