Author Topic: [GB] Sentraq TK78 Keyboard Kit  (Read 66873 times)
Offline doodersbrother
« on: Tue, 19 April 2016, 13:17:30 »
We're proud to announce that the TK78 is finally finished!
You can find our IC here: https://geekhack.org/index.php?topic=72329.0
And it is available for purchase here: https://www.massdrop.com/buy/sentraq-tk78-mechanical-keyboard-kit
It comes with a milled aluminum case anodized in one of four different colors. The pcb was designed by skullydazed. It features TMK firmware, full LED backlighting, with additional pins broken out and easily accessible, additionally all diodes and resistors are presoldered. The plate is laser cut aluminum also available in four different colors and supports the following layouts:
Here are examples of the colors available:
The kit includes the following:
Switch Plate
Aluminum Case
Blank PBT Keycaps
PCB
PCB Mounted Stabilizer Set
Gateron Switches
White LEDs
Mini USB Cables
The following items are also available as upgrades:
Cherry Switches
Dye Sub PBT Keycaps
Blue / Red LEDs
At this point the estimated ship date is June 15, 2016
We need a minimum of 30 kits for this to drop.
