Author Topic: Need some keyboard sleuths to help me identify some oldschool keyboards I found!  (Read 5940 times)
Offline Gdubb90
Hey folks!
A guy at work had mentioned to me that he was trying to get rid of some old electronics he had in his storage unit. Naturally I asked if he had any keyboards and he said yea! So I pilfered through the unit and this is what I emerged with. So what do you say, keyboard sleuths, can you help me out? :D
1) Tandy 1000 - personal favorite, really love the look of this one! Any more info about this one?
2) NMB RT101+ - definitely needs a good cleaning but it has a great click and feel to it. What are these switches?
Now for the real mystery...
3) Crystal Visions (cherry MX knockoff or not??) - I found two of these and I am confused to say the least. The model on the back of them says MX 11900, one of them has the cherry logo on front but a different sticker on the back. One has the cherry model MX 11900 on the back but no cherry logos to be found. Are they knock offs, fakes, or something else? The switches definitely look like cherry material, but they don't feel very high quality.
4) Mystery board - unsure about this one, the only info I could gather from the back is the model # MKB 931. Havent had much luck tracking that down.
Thanks in advance for any and all help!!
Offline smknjoe
What's under the keycaps on the Tandy?
The Cherries look like OEM Cherry boards to me.
SSKs for everyone!
Offline smknjoe
What's under the keycaps of all of them? I just see the one Cherry with Blacks.
SSKs for everyone!
Offline Gdubb90
1) Tandy
2) NMB
4) Mystery
Don't know about the Tandy.
The 11900s should have decent black Cherry switches, if you like linears. The touchpad is great but small and old-fashioned.
The NMB is Hi-Tek "Space Invaders" that are very desirable, but be very careful removing the caps so that you don't bend the "fingers" or lose the springs. The Alps-mount keyboard might provide a good set of key caps even if the feel is no good.
- D Trump 2026-10-24
Offline Mattr567
Those caps look alright, thin pad printed ABS. Still worth saving.
IBM P77, SKCC Green, 1984
Offline Gdubb90
Thanks for the info! I really appreciate it. I'll be doing some research on them for sure.
Offline Darkshado
Could the Alps mount one be of the "slider over dome" variety?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Fujitsu leaf spring
NMB Hi-Tek "space invaders"
Cherry MX Black (they feel like **** because they are)
Alps dome with slider
Offline Gdubb90
Fujitsu leaf spring
Thanks! I feel like I did alright for a free storage unit raid. The space invaders have a great feel to them, now I just need to do some serious cleaning...
Never grab the caps by the corners or you will pull up the top of the switch assembly. Be especially careful of the "fingers" in the switch leaf.
Offline chyros
  • a.k.a. Thomas
Fujitsu leaf spring
Like Fohat said, be careful with the NMB Hi-Teks. They're not nice switches to work with at all, try to avoid disassembling them if you can avoid it ;) . That said, they're really nice switches, and the caps are second to none :D .
Offline Gdubb90
Fujitsu leaf spring
I used a keycap puller to remove the other one but yea I'll probably avoid doing it any more, I would hate to damage the keyboard!
Any suggestions on cleaning it without having to remove the caps?
« Last Edit: Wed, 20 April 2016, 08:02:25 by Gdubb90 »
Offline chyros
  • a.k.a. Thomas
Fujitsu leaf spring
They clean up pretty well tbh. You can pull the caps, just make sure to remove them sideways to avoid pulling out the slider. I made a video of how I do it, long ago.
With the caps off, you can just brush and hoover out all the dust and dirt without too much of a problem :) .
Here's that video, hope you find it useful :) :
Offline Gdubb90
Fujitsu leaf spring
That's exactly what I needed to know, thanks Chyros!!
Offline invariance
  • ...here with all the other boson's
That mystery one is interesting, the FCC ID is registered to PC Expert Tech Co Ltd.
Ebay had a sale of an MKB931 although the manufacturing stamp on the back is slightly different and appears to have some german printed that is very hard to make out (below the sticker).
The seller stated the manufacturer as Allg. Gen.
Even though I don't know an ounce of German (we really need someone to translate this), and hopefully I don't insult anyone, I thought that i would punch in what I could make out into an online dictionary to try and make something of it: Funken.... could be Funkentstort - suppressed {adj against noise or interference}, nach - ?? to/past/on/for/in accord with/..., Allg. - short for allgermein = general, and Gen. - short for 'to' as in the direction of.
I would guess it states that it doesn't cause local electrical interference and has nothing to do with the manufacturer.
« Last Edit: Sat, 23 April 2016, 09:35:31 by invariance »
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline Gdubb90
Ebay had a sale of an MKB931 although the manufacturing stamp on the back is slightly different and appears to have some german printed that is very hard to make out.
Even though I don't know an ounce of German (we really need someone to translate this), and hopefully I don't insult anyone, I thought that i would punch in what I could make out into an online dictionary to try and make something of it: Funken.... could be Funkentstort - suppressed {adj against noise or interference}, nach - ??? to/past/on/for/in accord with/..., Allg. - short for allgermein = general, and Gen. - short for 'to' as in the direction of.
That is really interesting, thanks for the detective work! Ill look into that myself, my brother can speak a little German so maybe he can help out.
I also found those crystal visions boards really intriguing. If you look them up they have a website that says they have been selling those cherry keyboards since the 90s and they want almost $200 for a new one. Are they just buying them and slapping their logo on them? Even then, why are they so expensive? The keys don't feel high quality at all.
