Author Topic: Problems with IBM Model M  (Read 4366 times)
Offline Moopmoop
« on: Wed, 20 April 2016, 17:59:04 »
I ve encountered a problem with my IBM model M keyboard, it registers multiple keys at once "t" does "5t" for an example and "capslock" does "Capslock F1" and "backspace" does "backspace f9" and "y" does "6y" any help or pointers much appreciated.
Offline Bucake
Re: Problems with IBM Model M
« Reply #1 on: Thu, 21 April 2016, 04:42:12 »
when did it start happening?
how long have you had it?
did you spill something on it?
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Thu, 21 April 2016, 07:40:25 »
You have two traces that are bridging.
First thing I'd do is give the keyboard a couple of solid thumps to dislodge anything that might be causing it.  If not...
If this is an older one with the larger center controller, open up the keyboard and reseat the smaller ribbon cable in the controller.  Check it for debris. Might as well reseat both while you're in there.
If it's a later model with the small controller above the numpad, you'll want to do essentially the same thing, not sure what's what there though.
If there is still an issue, if you spilled something in it as the previous comment suggests you could have the bridge occurring somewhere in the matrix, there are ways to handle that too without doing a bolt mod.
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #3 on: Thu, 21 April 2016, 08:13:07 »
"If problems occur, throw against the wall. If problem is still present, repeat until gone. If doesn't solve problem, put in microwave. "  (I'm just joking, don't really do that)
But seriously, that sounds like spilling damage (creating bridges like mentioned above). Put it in the oven (slightly above 100 degrees) to let the water evaporate. that way you don't have to open your model M up and do a bolt mod (which is a pain in the ass if you are doing if for the first time). What could possibly go wrong!
« Last Edit: Thu, 21 April 2016, 08:42:25 by Olumin »
Offline 3K
« Reply #4 on: Thu, 21 April 2016, 08:40:04 »
At first I misread this line as
If problems occur, throw against the wall. If problem is still present, repeat until wall is gone.
Offline Olumin
« Reply #5 on: Thu, 21 April 2016, 08:43:14 »
That's even better.
Offline user 18
« Reply #6 on: Thu, 21 April 2016, 09:11:54 »
That would be a model F, not an M
Avatar by ashdenej
Offline Moopmoop
« Reply #7 on: Thu, 21 April 2016, 10:54:35 »
I got it yesterday, and before i plugged it in i cleaned the keys and was quite careful cleaning up the water on the keys themselfs and used a Q-tip inside the keys because water seem to get stuck in there i very well might have missed a spot.
I ve tried to shake it a bit i did manage to get the case open and all using the "bic" method and it was not many or even any rivets missing,
I did disconnect the connectors and repluged them into the control box? But that didn't work  i ve also tried to heat it up a bit using a hair dryer but that didnt work either
i think there might be gunk or something on the membrane.
Hopefully i wont need to do a bolt mod because i really dont have the tools for it or not yet atleast.
It's a IBM model M 1391411 (Swedish layout) from 1991.
edit: If i buy a Membrane assembly from unicomp by the "Enter the membrane assembly part number you wish to purchase" is it enough if i write "IBM model M 1391411"?
« Last Edit: Thu, 21 April 2016, 12:45:51 by Moopmoop »
Offline klennkellon
  • I like bottoming out
« Reply #8 on: Thu, 21 April 2016, 14:33:28 »
A model M could destroy a wall!
Offline 0100010
  • Not Sure
« Reply #9 on: Thu, 21 April 2016, 15:43:30 »
Yup.
« Reply #10 on: Thu, 21 April 2016, 16:27:40 »
Wellll.....a little late now, but this can be a teaching moment.  Always, always test a keyboard before cleaning it.  You want to know its state and if what you did was the cause of the problem.
Did you use any water on the q-tip when inside the keys?  Any water at all on the barrel plate assembly?
The simple thing you might want to do is to put the keyboard somewhere vertically, short side on the ground (so it's tall) and just let it sit for a few days.  It may dry out on its own.
Offline Moopmoop
« Reply #11 on: Fri, 22 April 2016, 02:52:05 »
[/quote]
Hah yeah quite stupid at my part i was quite excited so i kinda wanted it to be "perfect"
The q-tips was dry when i tried to get the water out inside the keys it looked fine but perhaps i missed a spot.
When i opened it up it was  dry inside didnt see any water or any sign of it either iŽll try to leave it alone for a few days and hope it works by then.
edit: i messed up the quote thing
« Last Edit: Fri, 22 April 2016, 02:54:03 by Moopmoop »
Offline y11971alex
  • Looking for Toronto meetup
« Reply #12 on: Fri, 22 April 2016, 15:01:04 »
Does Unicomp sell SSK membranes?
Offline klennkellon
« Reply #13 on: Fri, 22 April 2016, 15:17:32 »
Nope.
