Author Topic: Experimenting With Weighted Keys?  (Read 3499 times)
Offline PRISONER 24601
« on: Thu, 17 December 2009, 01:46:25 »
I'm going to assume that many of you have done this before, and I'd like to hear about your experiences. I mentioned in a previous thread that I had attached some 4.5g weights to some cherry brown keys, and the results were, I think, lovely. I really want to try it with an entire keyboard.
Seen above is my initial test (minus one of them falling off... only wanted a temp solution, so I used hot glue). the keys feel great to type on, and they give this sorta "rolling" effect, which is really cool. The reason for this "rolling", I believe, is that they keys have a lot more momentum behind them, and require only a slight tap to activate.
I'd like to get a hundred or so 4.5-5g weights and rig them up like this:
Of course, there are bugs to be worked out. The keystem should be centered right in the middle of the weight, which wouldn't work unless i modified my idea a bit. Another problem involves affixing metal to plastic and making it at least semi-permanent. 2-part epoxy would work, but I want something a bit more impressive.
Any suggestions or comments are appreciated. I'll update this in the morning, as I am very tired and cannot concentrate this late.
Thanks
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline ricercar
  • mostly abides
« Reply #1 on: Thu, 17 December 2009, 01:58:33 »
Where's my fishing tackle box? I have a ton of lead sinkers ....
There should be a quote somewhere about not wanting a thing until we see a cool picture or diagram. And maybe a long German word meaning the same thing,
Schadenkeylustennow.
« Reply #2 on: Thu, 17 December 2009, 11:16:39 »
Quote from: ricercar;143167
that was my first reaction too "HAY, LEAD SINKERS"... but they're roundish, and I'd have to melt them down, which I shouldn't be doing in my dining room :(
I'm hoping that somewhere, somehow, there's a guy on eBay with a big bag of little lead squares. Seems like something a hobbiest might have sitting around.
« Reply #3 on: Thu, 17 December 2009, 11:19:08 »
Quote from: ripster;143254
Just how weird do you think the average Geekhacker is?
Wait, don't answer that.
It's the Asian forums that scare me.
[IG]http://rapunzel.main.jp/col4/coldata/12.jpg[/IMG]
That doesn't scare me. I like the cut of his jib. Just yesterday, I was looking at these flat steel bars at home depot thinking "hmm.. my G80 is a little flexible and light..."
Offline J888www
« Reply #4 on: Thu, 17 December 2009, 11:35:29 »
Maybe it would be simpler to use metal key-caps instead of attaching weights.
     Metal Keycaps
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline itlnstln
« Reply #5 on: Thu, 17 December 2009, 12:15:51 »
Looking at that metal keycaps link again...  While we noted that the keycaps on the Cherry 'boards were blank, I think they actually came from Cherry like that (at least the ones on the black Cherry look that way).  The reason I say that is because the F and J keys are scooped like Cherry.  All the aftermarket keycaps I have seen use nubs.  I'm not sure why I brought that up.  Maybe I'm just wishing I could get some blank keys for my G80-3000.
« Reply #6 on: Thu, 17 December 2009, 12:15:51 »
Quote from: J888www;143293
     Metal Keycaps
simple, yes. incredibly awesome, yes.
but what do I look like, some thousanaire?
I've contacted my dad's machine shop, and the boss man might allow for a few special contracts as a favor to an employee's son. They've got those 1+ million dollar CNC machines and all that. It's something that I'd really like to do in the future. My brother is a whiz with CAD, so eventually I'd like to assemble a team of geekhackers (and others) to design and produce some metal keycaps right here in the good ol' USA. By my esimation, we would single-handedly resurrect the US steel industry with a few modest keycaps.
Right now, however, I just want to experiment with cherry blues/browns and some 4+g weights. it's cheap, and the effect would be similar. Plus, to get that "bouncy rolley" effect, I think the center of gravity should be at the top of the cap, right where your finger hits- not distributed evenly. That's just a guess, though.
Offline leos
« Reply #7 on: Thu, 17 December 2009, 14:09:26 »
Quote from: PRISONER 24601;143315
do it your self .....
choose one of then
link1
link2
link 3
link 4
any geekhacker here who has lot time to produce for us metal/other materials keycaps???
HHKB 2 Pro Black in use :typing:
Offline AndrewZorn
« Reply #8 on: Thu, 17 December 2009, 17:36:06 »
i dont understand the reason for cutting off the skirts
but yeah probably makes browns even LIGHTER
« Reply #9 on: Fri, 18 December 2009, 07:00:59 »
Quote from: AndrewZorn;143374
Well, I suppose you don't really need to. I just like taking off skirts is all.
« Reply #10 on: Fri, 18 December 2009, 07:02:42 »
Quote from: leos;143345
choose one of then
link1
link2
link 3
link 4
We had 2 CNC mills + a lathe in High School shop. I wish I could just go back there and use them :(
