Author Topic: Newegg} Rosewill RGB80 $50  (Read 3754 times)
Offline Lain1911
  • God of the Wired
« on: Fri, 22 April 2016, 10:21:47 »
Offline ander
  • I type, therefore I am
Re: Newegg} Rosewill RGB80 $50
« Reply #1 on: Sat, 23 April 2016, 02:18:15 »
This is certainly a great deal on a solidly made mechanical KB, as long as you keep in mind:
  • It has Kalih switches, not Cherry.
  • Though the box shows it with a spectrum of colours, you can actually set it for only one colour at a time. Rosewill said they'd fix this with a software update, but as they've now stopped producing this model, that doesn't seem like that's going to happen.
  • All the lighting profiles except purple are considered "gaming" profiles and disable the Windows key. So if you want to use the Windows key, you'll have to settle for purple lighting.
