Author Topic: Hi GeekHack.  (Read 3835 times)
Offline obviouslygene
Hi GeekHack.
« on: Fri, 22 April 2016, 10:42:28 »
Hi from Japan.
I'm from Singapore but live in Japan.
Used to use a razer blackwidow for gaming.
Recently I bought HHKB pro2 and couldnt go back to the razer.
Since the HHKB is my 2nd keyboard, I often wondered about trying other boards.
I also often build my own amps, so I'm really interested in trying to build one on my own!
Offline Kemindo
  • one world one promise
Re: Hi GeekHack.
« Reply #1 on: Fri, 22 April 2016, 13:59:47 »
Me too hi gher  :thumb:
Peace and Service
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hi GeekHack.
« Reply #2 on: Fri, 22 April 2016, 14:22:11 »
Hi from Japan.
Hi there, welcome ^-^
What kind of switches were you looking at? For that matter, is there a diy keyboard you've had your eyes on?
Offline gohono3
Re: Hi GeekHack.
« Reply #3 on: Fri, 22 April 2016, 15:11:30 »
Welcome!
I'm in the same boat as you.  HHKB is my second mechanical keyboard and I'm looking into building a custom 60% with the Hakko FX888 soldering station.
I also purchased Hasu's USB controller for the HHKB to make it fully programmable.
Re: Hi GeekHack.
« Reply #4 on: Fri, 22 April 2016, 15:50:15 »
I was looking at a GON NerD 60, Satan GH60 or I would really like a ALPS64
...but having handwired so many tube amps I could deal with just having a 60% alu plate and hand wiring everything else.
« Last Edit: Fri, 22 April 2016, 15:52:22 by obviouslygene »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hi GeekHack.
« Reply #5 on: Fri, 22 April 2016, 16:03:42 »
Mmm alps. I wish I could jump on the current infinity ergodox drop for the matias version. I guess you could pretty much make your own kit with your hand wiring experience.
Re: Hi GeekHack.
« Reply #6 on: Sun, 24 April 2016, 02:50:21 »
Welcome to Geekhack!
You mean there is life after HHKB? :))
Hand-wiring can be a bit tedious, but does mean that you're not limited to a pre-designed PCB and can create almost any layout you want.
Re: Hi GeekHack.
« Reply #7 on: Mon, 25 April 2016, 01:36:43 »
I guess so, I'm not particularly biased in anyway.
The only thing I'm hooked on to now is the 60% layout.
So I'm game to try any 60% board!
Re: Hi GeekHack.
« Reply #8 on: Wed, 27 April 2016, 06:03:10 »
Pok3r is a good choice!
Offline khirin
  • Do more, with less.
Re: Hi GeekHack.
« Reply #9 on: Sat, 07 May 2016, 09:23:04 »
Have you tried SpaceFN layout?
Re: Hi GeekHack.
« Reply #10 on: Tue, 17 May 2016, 13:03:19 »
actually not yet...
my kc60 is coming so probably i'll try it.
